SharkWerks Cayenne Bypass Exhaust Release
Hey folks, I just wanted to show what we've been working on for the 955 and 957 Cayenne models (2004-2010).
We are often asked for exhaust options for the Cayenne, and often times we are asked for a "sporty" solution that is not too loud. Usually owners also want to reduce the back pressure somewhat, especially on Turbo models.
Removing the OEM secondary catalytic converters seems to be the key to achieving both of these goals at a reasonable price. The primary cats are efficient enough to keep the emissions levels very low on these vehicles, and the horsepower benefits are significant.
Here's the OEM secondary cats, removed from a 2009 Cayenne Turbo:
And the honeycomb guts of the cat, where the exhaust restriction occurs:
The simplest approach was to replace these secondary cats with straight pipes. Using stainless steel and a CNC mandrel tube bender, we created a single-piece, high-flow tube to take its place. We created an analog to the OEM system that still uses OEM-sized diameter tubing and a factory fit flange for installation.
We also made an extra effort to use the OEM catalyst mounts by designing compatible hangers.
We have found that when bypassing these catalytic converters, a lack of OEM-positioned hangers can lead to vibration, rattling, contact with chassis, and extra stress on the primary cats in front of the system. It can also cause the muffler and pipes at the rear of the car to rattle. In other words, these hangers are critical to the entire exhaust system's operation.
Weighing the OEM system:
Total weight: 28.46 lbs.
Weighing the Shark Werks Cayenne bypass system:
Total weight: 10.38 lbs.
A side benefit is the weight savings of around 18 lbs.
The system also includes OEM Porsche exhaust gaskets to replace on the vehicle. The typical installation time is between 1.5 to 2-hours. This is the one of the easiest ways to make a Cayenne, S, or Turbo model sound a bit sportier while adding some horsepower.
Summary:
- Increased horsepower and better throttle response
- Sporty, more aggressive sounding exhaust
- Reduced turbo lag on "Turbo" and "Turbo S" models
- Weight savings of around 18 lbs (10 lbs, versus 28 lbs with OEM system)
- No "Check Engine" lights
For more check out our product page:
http://www.sharkwerks.com/products.php?pid=270
And if you have any questions just Email me to alex@sharkwerks.com
Summary:
Sharky, I took your bypasses off of my 05 Turbo truck and put them on my 09 Turbo truck. Have not noticed any rattles, just increased outside exhaust note.
My only question is why so much? $695, really? Fabspeeds are $580, so an extra $85 for hangers. I just don't understand why a bent pipe with hangers cost so much regardless if mandrel bent. I have wanted to try this but can't justify spendng that much for sound and loss of HP. I would really like to know what profit margin is on these items, i am guess 3-400%. If I had the time I would a set and take down to one the tons of exhuast shops here in Phoenix to have them replicate for probably 1/3 of the price.
I'm sorry it is just this overpriceing because we own a Porsche is just infuriating.
Will do shortly yes
Sadly not no.
There was an interesting thread on this topic on another forum recently. For roughly $150 guys were getting a nice set made by a local muffler shop.
I'm sure these Sharkwerks ones are nice pieces. I just see very complex custom exhausts for other makes that are much cheaper. So I often wonder about the porsche mark up.
Im all for manufacturers making money and understand that the volume of sales of these might not be as high as some other makes. Just interesting when the perception of the cost comes up a lot on certain products.
To me it is simple: If you do not like the price..do not buy...the seller not the buyer determines what to pay...
If Sharwerks is making a hefty margin so be it....It allows them to innovate rather than mass produce and dicount, and we like that..Actually the price on this bypass is very low compared to the GT3/RS bypass and they have sold it to most owners of these cars.
How much do you pay for a swiss mechanical high end watch or Microsoft office or the new OS??????
No need to hit Alex on the head..just do not buy
Really fookin loud!! Like an Austin Martin Vanquish Racecar. Like a V8 with straight pipes. Like a noise ticket within 48 hours loud. Or approx twice as loud.
BTW, Alex
Thanks for putting these together. I have been bitchin for a long time about the Fabspeeds and the fact that they don't even include hangers. How they could consider that unneccessary is beyond me. It doesn't take an engineer to look at that length of heavy exhaust and know that it needs some support. Plus everyone that buys them bitches about the rattle. Duh, it's just sittin there swingin in the breeze, course it's gonna rattle.
Prior to this our only option was Cargraphic, but after the exchange rate, they are even more expensive.
Roger that and we've got a few coming in over the next couple of weeks. One of our customers on the east coast actually made a clip from his 2006 CTT S so I'll try and get that going once I return from tuning the GT3 in Arizona
No worries and sorry it took so long It's been a pet peeve of Dan/James/mine for some time just haven't been able to get around to it! The Exchange rate made those ones in the $900 range plus shipping
Thank you!
Well two ways to answer that question... Firstly I saw the words, "I already like the way it sounds...". When I see that I'm just being honest but I'd say don't change it Second, we've done a few of those set ups before where the customer has had a Tubi, Cargraphic etc... and then bypass pipes. In my mind it certainly goes up a few notches in the loud department and we've got a few videos of that type of thing here in our cayenne projects section:
http://sharkwerks.com/porsche/cayenn...turbo-turbo-s/
If you want to try it (you'll reduce lag and get some power gains) and for some reason don't like it I'm fine to take it back etc... but check out the videos first. I don't know which exhaust you were thinking of combining it with either
BTW, Alex
Thank you!
Guys, the hangers are a absolute MUST for the pipes. Also these pipes are ultra high quality. The price may seem high but how many of these do you think Sharkwerks will sell...no matter the price...to Cayenne owners....especially compared to the amount of Cayenne's out on the road? Very very small amount will be sold, so Sharkwerks can not mass produce these in order to lower costs. These pipes are more of a ultra high end properly designed and built piece for your Cayenne....also much cheaper than after market mufflers if you want to look at it that way too.
