Replacing Wheels/Tires with OEM 20" - Warranty Issues
I'm thinking about ordering some OEM 20" Sport Technos to replace my stock 18" wheels and tires on a 08 CS. I have 1 year, 8 months left on my factory warranty and 2 years after that on Porsche certified warranty.
The Technos will come from a 3rd party but are indeed OEM, as well as a brand new set of tires that will be Porsche approved.
I do NOT want to void my warranty. Should I have the dealer install the wheels and tires? I'd rather not pay a premium on labor.
I know the best answer will probably be "ask your dealer", but what do you guys think?
Rocky Mountain High
I'd be shocked if OEM 20" wheels with N-spec tires would void your warranty, no matter who installed them.
Don't see why that would be an issue as long as they're not damaged and don't ruin something else.
On wheels that large, I typically would only have the dealer put them on. Many of the "cheaper" shops (including goodyear, sears, etc) often don't have roadforce balance equip or equip to handle 20" wheels to begin with (or the local store won't in my experience). All to save $20 or so...not to mention some dealers may give you a free alignment/check since your pig is under warranty (I did from my dealer when I had them put new tires on, which weren't even n spec).
Just call me Pops
My dealer didn't have the Hunter and did an awful job balancing my 20s both times. So find out first if your dealer has the equipment.
I found a shop around NY that had the Hunter and they've been doing it since.
Enigma, did you go with OEMs or aftermarket? What kind of tire did you go with? How is the ride compared to your old wheels/tires?
Just call me Pops
I've had aftermarkets, and never had any warranty issues.
I've had P-Zero all seasons, which I didn't like and have been using Michelin Latitude Tour HP. I think I'm on my third set and no complaints so far.
I honestly don't remember how the 18s feel, because it's been 3 years since I've made the switch.
Jay, unless your dealer is offering competitive prices, I'd buy the tires online personally from TireRack or Discount Tires. Much cheaper. And I'd also skip the n-spec tires unless you're dead set on it. The P!g doesn't need expensive tires to be happy...
Just an FYI on the warranty issue.
Magnuson Moss Warranty act
You could put wooden wagon wheels on the Cayenne from "fly by night" industries. The only warranty work they could deny is damage caused directly by that wheel and the burden of proof is on them.
Agree with any shop, make sure they have the latest Hunter high speed roadforce balancing equipment.
just because a dealer has roadforce doesn't mean they really know how to use it. I have been told by my Hunter tech that dealers usually don't have the full training needed for the correct way on the machine
