06 turbo - i just changed oil and air susp stuck "regulation switched off"?
had the car up on the lift, changed oil no biggie, and now air suspension up front will not go down, warning says regualtion not permissible.....anyone else have this problem
turn ignition key to the point right before actually turning the car on and hold the level switch up for 5-10 secs this should turn it back on. This is the process I just used to turn on/off when I had it on a lift doing my brakes.
