Thinking about buying a cayenne - questions...
So I am thinking about buying a used Cayenne GTS MANUAL.
The thing that is holding me back is not enough power. I am a bit of a hp junky. I have searched and it seems there are no Supercharger systems available for it?
What are the realistic HP gains from chip, intake, exhaust on a GTS?
How about a manual trans swap on turbo? Has it been done? Can it be done?
Is there a way to control the center differential manually (an after market tuner/programmer, like the lowering module)? I belive the normal setting is 62% rear, but 100% can be sent to the axle that needs traction. I would like the abaility to set it for more rear bias as I like to hoon around in massive oversteering drifts.
Thanks for your help.
i thought that 2ndy cats and ecu module gave 25 hp or something like that?
they are fun machines and 0-60 isn't the whole measure of that intangible
Rocky Mountain High
Sounds like you'd be better off with a Turbo or a Turbo S.
Rocky Mountain High
Rocky Mountain High
Sounds like horsepower is more important.
