I want to find where this stereo plug leads to...
Old 12-25-2009 | 01:50 PM
MyPepper's Avatar
MyPepper
Question I want to find where this stereo plug leads to...
anyone have instructions on removing the console?
Old 12-25-2009 | 02:02 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
https://rennlist.com/forums/porsche-...e-removal.html
BTW, it's a good thing it's the holiday season and MadFox isn't around...
Old 12-25-2009 | 02:07 PM
MyPepper's Avatar
MyPepper
... with that said, thank you and Merry xmas!
Old 12-25-2009 | 02:50 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Newbies...Bah Humbug
Old 12-25-2009 | 03:29 PM
MyPepper's Avatar
MyPepper
Post OK I FOLLOWED THE PLUG W\ PICS ANYONE KNOW NOW?
Attachment 408139
Name:  plug to rca.jpg
Old 12-25-2009 | 04:46 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
AFAIK, t here are no analog inputs on the back of either headunit (CDR or PCM).
When you say 'back of nav' exactly what are you referring to? Did you remove the headunit from the dashboard?
I'm guessing there is an FM modulator tucked in behind the headunit...it should be simple enough to "find" it...insert the jack in your console into an iPod (or any audio source), play audio and then scan thru the FM frequencies (manually or seek) until you hear the music.
Old 12-25-2009 | 08:35 PM
MyPepper's Avatar
MyPepper
Post MYSTERY PLUG RESOLVED!
IPOD IPHONE Resoved!!! Found a toggle switch by my leg (pic below) when I flip the switch not only does my IPOD/IPHONE work VIA my NAV head unit and steering wheel controls, so does the phone! All using that 3.5 plug pictured above, despite what some of you thought...p.s. when I said NAV I was referring to navigation which came with my '04 CS.
Old 12-26-2009 | 04:36 PM
Coyote99's Avatar
Coyote99
Can you post a shot of what the Nav screen shows when hooked to the iPodiPhone?
Old 12-26-2009 | 04:42 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
So, the question remains: which aftermarket adapter is installed?
Old 12-26-2009 | 10:08 PM
MyPepper's Avatar
MyPepper
The NAV screen remains the same when plugged into my iphone, I can use the steering wheel controls, radio controls or iphone controls to operate the iphone/ipod.
Old 12-27-2009 | 01:03 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Yes, but that is not an OEM design/option.
There must be an aftermarket adapter hiding back there somewhere, knowing the brand/type will be useful should it fail and you can't communicate with it to get S/N or P/N information, let alone know who to call.
Old 12-27-2009 | 01:16 PM
wirunner's Avatar
wirunner
The adapter is probably hiding tucked in the passenger firewall. There is nowhere else even a small one fits.
Thing I find odd is the phone only works when plugged in? So it's not BT? Maybe I am reading this wrong. There should be a little aftermarket microphone hiding somewhere obvious too.
MyPepper - What every one is telling you is that even Porsche OEM did not offer this and there is no way to just link in an iPod to the headunit. This reminds me of the MoBridge unit with the toggle on/off switch and I am guessing someone rigged a 3.5 adapter instead of the std iPod one (prob bc they didn't have an iPod).
Any how do you know the white/red RCA plugs go to back of Nav? Take a picture and show us.
Old 12-27-2009 | 04:48 PM
mudman2's Avatar
mudman2
Moderator !x4
Sounds and looks like a Mobridge
Old 12-27-2009 | 06:05 PM
MyPepper's Avatar
MyPepper
Where else would these rca's be headed if not to the back of the nav? There's no more slack and they run straight up and back behind the unit...
Old 12-27-2009 | 08:21 PM
wirunner's Avatar
wirunner
Attachment 408508
Our esteemed moderator, mudman2, has a website with pictures of the back of PCM2. If I had the link, I'd post it, but someone else will help. Anyway, you'll clearly see there's no RCA inputs or any aux inputs for that matter.
And your picture shows them where the cig lighter usually is. Let me tell you after spending much time both in that location (I have SAT there) and behind the PCM, I highly doubt that's where they're running to. That particular location (of your pic) is easy to run them behind the glovebox and to the firewall, which is where I predict we will all find the answer.
Quick Reply: I want to find where this stereo plug leads to...
