18's don't fit on 2009 CTT?
I was told this morning by the shop that was to install my 18" rims/snow tires that they will not fit over the calipers. They fit fine on my 05 CTT. I thought that the Turbo S had the larger calipers. Were the 09's enlarged over the 05 calipers?
Well, as I was checking out tirerack.com on sizing (which shows 18's fitting my 2009 truck) the dealer called and told me that they will NOT fit. So looking for 19" set up and will have my 18's for sale soon as I can take pictures. They have TPMS.
Check to see if yours uses different pads. If it does, then they may be right. I can interchange my 05 CTT and 08 CS with no problem, but maybe the 09 CTT uses the 05 CTTS brakes.
I was under the impression that the Turbo S had the larger brakes. Will check!
Have posted rims/tires in For Sale thread
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
here is a link to where I got my rimms...Really nice replicas for a lot less dough.
WWW.OEWHEELSLLC.COM.
good luck.
Been there, done that
...sold the 18" off my 04 CTT. The only thing that will clear PCCB is 20". Also if you do not have ceramics I still do not think that 19" will clear the dust plate so you are better off getting a set of 20" and mounting winter tires on them...Tire rack has false fittment for 09 CTT S.
good luck.
good luck.
With 19's on the truck and summer tires presently, I assume that 19's and snow tires mounted will work.
