View Poll Results: How long did your stock battery last and what did you replace it with?
Less than 3 yrs., replaced with OEM (Porsche)
0
0%
Less than 3 yrs., replaced with aftermarket
3
4.05%
3 - 4 yrs., replaced with OEM (Porsche)
1
1.35%
3 - 4 yrs., replaced with aftermarket
6
8.11%
4 - 5 yrs., replaced with OEM (Porsche)
10
13.51%
4 - 5 yrs., replaced with aftermarket
1
1.35%
Still on stock (Porsche) battery
53
71.62%
Voters: 74. You may not vote on this poll
Old 12-08-2009, 11:39 AM
  #31
ljugete
ljugete's Avatar
My last Cayenne S had the two battery option (never had to replace them). Traded it after 135K miles.
Old 01-08-2010, 06:10 PM
  #32
JW3
JW3's Avatar
cab&coupe - nice garage !
Old 01-08-2010, 07:17 PM
  #33
Basal Skull
Basal Skull's Avatar
I'm of the opinion that batteries will last a long time/the life of the car if maintained properly.
Old 01-08-2010, 08:20 PM
  #34
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
I would disagree. The chemistry of a wet cell does not lend itself to long (service) life in an automobile.
Old 01-08-2010, 08:55 PM
  #35
cab&coupe
cab&coupe's Avatar
Thanks Johnnie, the 997 replaced the 3.2 Cab unfortunately.
Old 01-08-2010, 09:55 PM
  #36
Basal Skull
Well a wet cell secondary battery can last a long time, if not for the sulfuric acid falling off the plates, which can be minimized by maintenance and not discharging too much/long time. Batteries that are used/discharged/charged frequently last a long time. Battery companies I'm sure would like you to buy low/non-maintenance batteries that are designed to fail. Not a big deal regardless, batteries are relatively cheap.
Old 01-08-2010, 10:21 PM
  #37
BG993
BG993's Avatar
'04 CS, 114K, Still on OEM Battery....
Bought in August '04, livin' on borrowed time!
Bill
'04 Cayenne S
'95 Carrera (gone and not forgotten...)
Old 01-09-2010, 12:30 PM
  #38
BobbyB
BobbyB's Avatar
04 CTT - purchased in May 04, still on original battery, 64K miles - fingers crossed
Old 01-12-2010, 01:52 PM
  #39
Jones
Jones's Avatar
Almost 7 years, 100,000 miles and counting on original battery.
Old 01-19-2010, 01:03 AM
  #40
INURGRL951
INURGRL951's Avatar
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
I replaced my battery with twin optima 34R batteries at 60k on an 06 cayenne but I got camping and charge lots of things on the outlets.
Just an F.Y.I you can easily put a single 34R optima battery in the cayenne under the set I got pics if needed before I yet again upgraded.
Old 01-20-2010, 11:38 AM
  #41
JW3
JW3's Avatar
Replaced mine at 58,752 miles (6 weeks short of 4 years old). I only replaced it because when I hooked up the Porsche Battery Tender the green light came on like normal but all at once the orange light started blinking rapidly. According to the manual (and IDRTFM) that blinking orange light indicates there is a positive discharge and the battery should be replaced.
So, as I am no electronic wiz and did not want to go toes-up on the road, I replaced the battery. I feel better.
Old 01-20-2010, 12:33 PM
  #42
Slow Guy
Slow Guy's Avatar
I don't blame you, as I said in another thread I consider a battery a maintenance item, just like air filters, replace them as needed.
I suspect that the first few months of a vehicles life goes a long way toward determining the life of a battery. If the vehicle sits for extended periods on a dealers lot and has to be recharged a few times that will shorten it's life. If the vehicle is delivered shortly after arriving and is driven regularly keeping the charge up the battery will last longer.
Just my theory...
Old 01-20-2010, 01:24 PM
  #43
JW3
JW3's Avatar
Sound theory Bill. I picked my CTT up in Leipzig and the only time I hooked up the trickle charger was when I was not going to drive for 3 or more days (due to work). During my research for the CTT purchase, I saw the battery issues going on and asked my mechanic in Germany "how long" and he said watch the trickle charger and he recommended every 4 years (maintenance) just to be safe. So, your assessment is spot on.
Old 03-03-2010, 04:59 AM
  #44
racer_65
racer_65's Avatar
If my battery is dead (wife says she left the lights on), will it hurt the electronics if I jump start the car? or is it better to use a trickle charger instead?
Old 03-03-2010, 10:20 AM
  #45
Slow Guy
Slow Guy's Avatar
I'm not an electrical engineer so take this for what it's worth.
If you need to drive the car right away go ahead and jump it, just make sure you hook the cables up correctly. However, if you have the time I would put it on a charger, a trickle charger may not work though if the battery is fully discharged. They're designed to maintain a charge, not "activate" them. I would use a charger with an output of somewhere between 6 and 10 amps. Personally, I have 3 chargers (overkill I know), a Battery Tender (1.5 amps), a 2/6 amp charger and a 2/10 amp charger. In your case I would use the 2/10 amp charger on the 10 amp setting to fully recharge your battery. I would keep the windows of the Pepper open just in case the battery vent system is not working properly, since the battery is under the driver's seat.
I've heard stories that the trickle chargers will fully charge a dead battery but it takes 3 - 4 days to do so. Best of luck.
As for jumping the Pepper, I'm sure they have voltage surge protections built into the cars electronics but with the quantity of electronics in these cars I would prefer to err on the side of caution. I would also make sure all power accessories are off prior to jumping the car. JMHO
Quick Reply: How long did your stock battery last and what did you replace it with?
