Air Suspension Question
If you have air suspension on your Cayenne, does the compressor run every time you first start the car in the morning?
Mine does, and I'm trying to determine if this is normal; or if I have a slow leak that causes pressure loss when it's parked over night.
Thanks in advance for sharing your experience.
If you put the cat bypasses on, you do not hear much at startup except exhaust rumble.
Interesting. Another poster over on Renntech.org says that PSM is not related to the air suspension, but PASM is. My dealer's tech also says that there are two different control modules for PSM and the air suspension.
However, at the same time that I got the PSM FAILURE message, the air suspension compressor stopped working, so there either must be some interaction between the two or it's just a big coincidence.
I am assuming you have the air-suspension?
It should read something like "air suspension failure". But usually comes and goes.
Either way what's happening to you is not normal. Take it in and get it checked out under the warranty.
Appointment for service (again!) next Monday. I wonder if they'll keep it for a week again this time.
Air suspension and PDCC. The "PSM FAILURE" error message and teltale in the cluster are gone after two starts today. Air suspension is making all kinds of funny noises and the compressor is running way more than it should. All this with less than 1,000 miles on the clock.
