Help Confirm Audio Approach
I recently purchased a 2008 Cayenne S with PCM (and CDC). It does not have satellite. I want three things: Bluetooth, Ipod/Aux in and satellite integration.
After searching the numerous threads here, I'm going the mobridge route to satisfy my #1 and #2 desires.
I am still confused however on what to do to get satellite. Would it just be easiest to get an aftermarket unit, hardwire the FM modulator and stick the antenna in the rear spoiler or is there a better option that would allow me to use the PCM headunit?
I'm spending more time trying to understand this than I ever thought I would! My 964 was much simpler - tape deck and the sweet sound of an air cooled engine!
Thanks.
Thanks.
Super Moderator
Needs More Cowbell
Needs More Cowbell
There is/was an OEM satellite option (XM or Sirius) for the PCM 2.x units.
You can even see some pictures of the components/parts lists here:
https://rennlist.com/forums/997-foru...c4s-cab-2.html
Another option would to be to abandon the hardwire FM modulator and simple share the analog/AUX/line level input to the mObridge between the satellite radio and the ipod.
Another option would be to buy a new Cayenne with PCM3.x, thus giving you OEM install for Bluetooth, iPod and Satellite radio....and a color touchscreen.....go ahead, you know you want to.
Apart from that, I have no idea
When floormats are an option on Porsche vehicles I don't think they would give us audio features as standard. I'm almost surprised they give us AM & FM together....
Good idea about the mobridge aux - I will do that once the mobridge is installed.
In the interim, I just tried to use the built-in FM modulator in my XM receiver and had no luck. I'm assuming that it is because the FM antenna in the car is on the rear spoiler and it is too far away from the XM unit's weak modulator?
The best source for products and service support that I've found is:
http://www.tss-radio.com/
Super Moderator
Needs More Cowbell
Needs More Cowbell
Even in cars with front windshield antennae, the wireless modulator doesn't work very well.
In the absense of a line level analog (aux) input, a hardwired FM modulator works best.
FWIW, I bought a Sirius setup for my bride's Excursion (her daily driver) and the hardwired FM modulator actually works quite well from a S/N perspective.
