Cayenne Brake Job
Can we get some feedback on stock versus (Hawk) ceramic pads on stock or Zimmerman rotors?
I have been advised by some really good folks on this forum about technical stuff and that is very important. But I am interested in hearing about usage. Are ceramic pads better, i.e., brake/stop better, longer wearing, cause less wear on rotors and/or fade less? Look forward to comments.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Since brakes are not a difficult job (if you have the time and space to do them), I just hired one of my employees' husband who is a mobile mechanic to do it. Front and Rear rotors, brakes and sensors. $930 and he did it while I was at work.
Now my wheels have a whole new set of dust on them!
I have been advised by some really good folks on this forum about technical stuff and that is very important. But I am interested in hearing about usage. Are ceramic pads better, i.e., brake/stop better, longer wearing, cause less wear on rotors and/or fade less? Look forward to comments.![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Metallic pads: wear quicker, dust a little more, but IMHO are better for heavier vehicles as they have a higher friction level and are better under high temp.
Bottom line kind of depends on your driving style, where you spend the most driving time (track, street, etc) and whether you like to clean your wheels more or less, lol
There are I'm sure several of those out there with vast more experience than I so I'll defer to their expertise...as well as LTC's colorful commentary!
Personally I like the ceramics for the lower dust, but I've had both and can't tell a ton of difference in stopping power...but then again, I'm not hauling my Pig around the track other than an occasional parade lap while the 951 is cooling off...
littlejt1 - thanks very much for the feedback. I will go with the OEM parts - they've done a great job in Germany and here. I will just continue to wash the Pig more.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I just replaced my Cayenne front pads today. It was indeed super easy. The brake pad light was not on yet, so I was expecting that I could re-use the sensors. But alas, they were impossible to remove from the old pads without breaking them. So I had to run out to the nearest Porsche dealer and buy them for $22 each. Which is twice as much as an internet order from Sunset Porsche. (where I got the pads). Lesson learned; plan on replacing the sensors and thus order them at a discount.
The rear pads still have some miles to go. Given that I know I will replace the sensors, I will just wait until the warning shows up on the dash.
I just completed my brake job too. It was a two weekend job because I didn't have the 16mm Triplesquare bit for the back rotors. Overall a relatively easy job. The first rotor is a pain until you figure out how to get all the parts off then it's much easier.
I did ended up using OE Pads even though I bought a set of Hawks ceramics I think. After I read that the bite of the Hawks may not be as good as OE I decided to pass.
Make sure you get the brake pad kit and new sensors. Even if you do not have the light on, you probably gone through a lot of the sensor so just replace them.
My bill from the dealer was $1k...Sunset, suncoast...whatever, may have been a little cheaper maybe...
Oil change is next weekend...Good thing I have a lift. Although it did wheeze a little lifting the pig.
I am trying to replace the front brake pads and have on my 2013 Cayenne.
I have these questions...
1. The tripple-square bolts that hold the one piece caliper on, how to get them off .. is an impact wrench required ? I have the tripple-square sockets with a 4 inch spline and the spline tends to twist when I try to get the bolts out ... I think I need to try a socket with no spline for a more direct connection to breaker bar.
I did try some WD40 to no avail.
2. Is there a recommended triple square socket / supplier ?
3. Where can I find the torque specifications when I re-install the tripple-square bolts ?
4. There a best jack stand solution .. seems to only be one jack point and I am using that with a backup hydrolic jack at the front part of the chassis but maybe should put the jack stand there .. I have seen a combined jack ? jack stand but not priced it ..
Thanks, Bob.
Thanks, Bob.
Thanks, Bob.
Thanks, Bob.
https://rennlist.com/forums/porsche-...ake-job-2.html
Also see my post in that thread (post #17) for torques. You just need to remove the caliper bolts and lift off the calipers and slide out the pads - see attached too. The caliper bolts can be tight but I used a breaker bar and worked fine.
Good luck.
For the OP: I replace wear sensors and all recommended bolts and brake hardware.
LOL! I just replied to an 8 year old thread! I wonder how many times he's replaced pads since then?
Received 1,149 Likes
Aussie-Bob, those bolts are one-time-use. Torque (from memory) is something over 100ft/lbs - so the bolts stretch when tightened. Porsche requires replacement whenever they're disturbed.
See this topic and posts - good helpful info.
Good luck.
Good luck.
Hi Rennlist'ers , I am looking at replacing front brakes on my 2013 Cayenne .
1. What is the best way to get the get the two tripple-square blots off holding the caliper on .
I some l the tools and want to know if an impact wrench is required to get them loose. I am wanting to use a 3/8" breaker bar.
I have the parts , caliper holders and the piston spreaders but need to get the two bolts off.
2. Where can I get a workshop manual that would specify torques for getting it back together right.
Thanks in Advance, Bob.
And the bolts - on all models - are specified one-time-use by Porsche, but especially on the radial mount calipers where torque on them is 104ft/lbs. You should NOT use any impact driver to remove them. The correct driver (triple-square on the radial mount drivers) and a 3/8" breaker-bar should be all that's necessary.
If you do have the radial mount calipers - there are some inexpensive special tools available that make the job WAY easier. These are pins that screw in place of the bolts, and you slide the caliper up on the pins to R&R the pads. Since the calipers are very heavy - these are well worth getting. Details are in the manual and on the ALLDATA website. SnapOn has a website that sells the tools for about $30.
A workshop manual can be found on Ebay - a PDF copy. It's usually around $35-40.
IMHO - (and I have both) a better option is to subscribe to the ALLDATA.COM version made for home wrenches.
The factory manual is for all models - and it repeats every section, even if absolutely identical - for each model. It's not terribly clear what model each section is for. It takes quite a while to get comfortable with. It is not easy to search for specific info due partly to it's size - 11,000 pages.
The ALLDATA website version is for your specific model and year - and is much easier to navigate. It's also inexpensive - there are frequent discounts offered. Right now it's $16.95/year and cheaper for multiyear subscriptions.
Its at alldatadiy.com (and I have nothing to do with alldata - just passing on my experience.)
Thanks Don for all the details,
Just got back to this ... ( have been living on 2.5 gallons of water per day which is a distraction ), the Cayenne is the 3.0 Diesel ... not sure on the exact model number but it is the diesel released in the US in 2013.
I have the caliper holders and the triple-square sockets. I don't have the impact wrench but do have torque wrenched and a longer 3/8" bar to get the bolts off ... I assume the tighten in the usual direction as I am always unsure but don't see any reason why they would be different. On the triple-square bolts there some symbols ... I will try to add an image.
One time use on the tripple-square bolts that hold the calipers on ... that is an issue as I will need to purchase them.
First thing is I will get the shop manual on line to work off.
