DFI engines with valve carbon buildup?
So that is where all the oil goes. My 2008 CS (DFI) uses more oil than my 2005 CTT (non-DFI) Does anyone think that those total fuel system cleaners will help this?
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
The total fuel system cleaners do work (BG,etc). But you are not thinking about what you are saying. This is a DFI engine, Direct meaning below the intake valves, Directly into the combustion chamber!! Now that were are clear about that, I have seen several DFI Cayenne intake valves look just like this one, very low miles too, less than 5k. I personally think the build up is due to the lack of fuel injection on top of the valve, as in the MPI engines to allow products like BG control deposits on the valves. I also noticed that the build up was more on the middle cylinders 2-3 and 6-7. This is were the majority of the crankcase gases vent, hummmm? All oil mist and air, no fuel to help aid cleaning, thats the problem IMO
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
A intersting thought, the new service interval is now every 12k for the 2nd gen 9PA's. LOF @12k, Minor (major turbo) service @ 24k (plugs on Turbo!!) , Major @ 36K (plugs on S). Pretty pricy little pig to feed.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
I am using Mobil 1 0W40 in both my Cayennes. My 2005 CTT is using about 1 qt per 2K, and the 2008 CS is using 1.5 qt per 2K. Not as bad as others and I suppose well within Porsche spec for normal.
porsche52,
So what is the remedy from Porsche on the DFI issue?
I have seen this issue wide spread from VW, AUDI and BMW.
Following the VW side looks as if some people are developing or developed a catch can system and are messing with the PCV system to control blowby and so on to reduce the issue.
Out of all the motors the RS4 V8 seems to have the most issues with the build up, even the oil in the DFI cars seem to be toasted by 3k or 5k from the heavy dilution of fuel.
Keep us updated.
Keep us updated.
porsche52,
Keep us updated.
Keep us updated.
Hey sorry to kick a dead horse. I took these pictures and somehow they pollinated all over the interweb. Any questions I will try to visit here a little more.
What have you done about this? Did the dealer recommend an engine cleaning exercise such as Techron, or GM TOP Engine cleaner or Seafoam?
Thanks.
I did the work. It was a cayenne turbo w/ 25k on it. It is driven hard. Not sure about distance but where the owner lives nothing is "short". This vehicle had no problems resulting from the carbon on every valve. Performance, idle and cruise actual values were all normal. If he does come back for this concern I would like to try walnut media blasting and a cleaner during services. None of this is up to me.
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
So it looks like the 2nd gen cayenne has there own share of problems. But wait I got an 04 Turbo and a 06 Turbo S and either one does not use a drop of oil I use castrol full sytec and change my oil every 4k-4.5k because I noticed the oil consumption start around 6k mile on the oil so why add a fresh quart to old oil just change it at an earlier mileage. I remamber when Porsche had the oil change intervals at 20k!!!!! That's where I think one mistake is even 12k now is way to long especially on a turbo cayenne.
