Warranty Question
Warranty Question
Say I was going to get a remand motor and I still had about 6 months left on my original factory warranty. Would I get some sort of warranty with the remand motor for 2 years or so, or would I just get the remainder of my original factory warranty.
Thanks,
Thanks,
My issue with the reman is that it may have the old coils that will have to be replaced.
Yes it's my 05 CS. I started to use 1.5 qts of oil in about 700 miles and blowing smoke at startup. My vin also fit into the TSB for the oil scavenger rings being installed upside down. Finally had a leak down, compression test and Cyl 4 was an issue. 20 % down. They got a bore scope and saw lots of scrapes and damage to the cyl 4. Also, the plug was oily. I had the coils replaced too.
The warranty on the engine will apply irrespective of the vehicle warranty. It should also be for the entire assembly so if the coils need to be replaced later they should be covered.
HTH,
Scott
You will get a 2 year warranty, and you can ask the tech to double check the PN of the coils and if you indeed get old ones he can swap them from old motor to new.
Mark
Mark
DEALER installed "labor&parts" carries ITS own warranty INDEPENDENT and INTO ADDITION to regular 4y/50mi car warranty. Every part, installed by the dealer carries it's own ADDITIONAL warranty, which may EXTEND specific part warranty BEYOND standard 4y/50mi...
OZRacing
If the reman engine is installed and paid for under the original vehicle factory warranty, then the warranty on that engne would last until the expiraton of the factory warranty.
If , alternatively, the engine were installed and paid for by the customer, it would carry the full 2 yr parts & labor warranty if installed at a factory authorized dealer.
In other words, if Porsche warranty buys you an engine 2 months before the factory warranty runs out, then all you are guaranteed is the 2 months remaining on the factory warranty.
Exceptions can and have been granted in the interest of goodwill and in recognition of customer loyalty, but that is no guarantee.
I hope this is helpful.
