Cigarette Lighter
4th Gear
Cigarette Lighter
Is the cigarette lighter supposed to swivel up when the ashtray is pulled out? Mine just stays down and it's hard to pull out since I have to "swing" up the lighter holder w/ one hand and pull out the actual lighter w/ the other hand. TIA.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Either way, simple fix for the dealer (assuming you're not "naked"); if you are "naked", simple call to Sunset Imports for a new part at cost + 15%
4th Gear
What's wrong with matches??
Anyone know how to remove the ashtray assembly so I can fix my lighter from not popping up?
Also the center overhead light switch doesn't work either. Suggestions to how to remove the plastic cover without breaking it?
