CAYENNE OWNERS THAT HAVE NEVER HAD COILS
#33
I spoke too soon. (See post #3 above).
Turns out I do I have coil issue (at 39,8XX).
Went to the dealer today for 40K service today.
On Saturday (2 days before my scheduled service), truck stalled backing out of the garage. (WTF?) This morning, before heading off to the dealer, it stutterred after ignition.
I told dealer about it when I got there and they said it was a cracked coil issue. They replaced the coils during the 40K service. Everything seems fine now.
The coil problem seemingly happened overnight.
#35
Originally Posted by rome
I told dealer about it when I got there and they said it was a cracked coil issue. They replaced the coils during the 40K service. Everything seems fine now. The coil problem seemingly happened overnight.
Case in point.. I finally am at my office and bothered to pull out the files.. I started complaining about cold idle/roughness at 7800 miles.. car stalled at 34,000 miles one time.. never could find codes or faults stored by PIWIS.. at 46,000 miles and two years of ownership.. found all 8 plugs prematurely worn and ALL coils had hairline cracks (allowing moisture) thus replaced all.
So, it would seem that you get used to it and it seemed worse during high humidity (spring/summer).. if you have part number 948-602-104-00 ... it is eventually going to fail.. only later models got a new coil design (or at least that is what I think.. brad/ltc?).
#37
I believe the Cayenne got mad it me because I've been keeping it outside since I got the 993 about a month ago.
I remember Larry's Cayenne.......never washed/waxed, baked on brake dust that a Brillo pad wouldn't remove........well, it was washed by the dealer when it was in for service (I know, when was it NOT in for service) who either felt bad or was embarassed to have it sitting on the lot looking the way it did.....
Why wash a pig....it's only going to go back and roll in the mud again.....save water, dont' wash a Cayenne.
#39
#41
Originally Posted by EnigmaWmn
I have had all of the symptoms (currently slightly under 41k) for a while but service department never found anything wrong. Then again, I might be one of those "lying customers" that firehawk encounters on daily basis :-).
#42
Originally Posted by lic265
Mad Fox, did your coils fail in the 04 or 06 model?
'06 Tit.S has been absolutely bullet-proof to date. 9 months/12K miles.
#43
it's coils. insist they check..
#44
C'mon, MadFox, you don't think I insisted??? Was told that the service manager checked them PERSONALLY and found them to be in perfect health. Will insist some more next week.
