Rear luggage comartment side-panel lining removal?
So I searched the archives in hopes that somebody else has removed the panel and has the instructions for removal......no luck
The "luggage compartment side-panel lining" is the piecce that covers the amp above the CD changer.
Here is the official location:
Cayenne technical manual 70 03 19 --Removing and installing luggage compartment side-panel lining.
Anybody have the instructions/pdf/etc.? I tried to contact Loren over at Renntech but haven't heard from him.
Thanks!
Thanks!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by mudman2
Dell, email me I have lost yr email address, I have what you want.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by LVDell
I tried the explosives. But all the did was bounce off the panel ![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
If explosives don't work, I'd suggest setting phasers to 'kill'.
Cows-4-Rent
I got the amp for replacement now I need to know how to do this as well. Feels like a lot of breaky things back there and before I get into it by trial and error, does anyone have instructions on which pieces have to come out and how to do it?
Budget a few hrs. to do the deed. It's one of those "I only need to remove this piece to get to what I want but I have to remove 10 pieces to get that piece off". It would be much easier to Dremel a (bigger) hole in the panel and duct tape the panel back on when you're done.
Have fun.
Have fun.
Cows-4-Rent
Unbelievable PIA...
Does the little pad just pry out past that metal post?
I haven't go to the seat belt removal yet.
Somewhere Larry is laughing.
Cows-4-Rent
Well the job is done and the radio actually works!!!!.
I never got the liner off completely but was able to access and change the amp without full removal.
Real PIA? YES. Worth the savings of $1,600? For me, YES.
There were some twisted minds that designed that thing.
Thanks Mudman, I appreciate your help and information. Time for a bit of celebration.
When removing the side panel, do you have to remove all the other pieces as well? Like Remove the C Pillar Trim, the rear roof lining, the D-Pillar Cover, luggage compartment trim, and cover for lock mount? If so, does anyone have those instructions?
