Rear luggage comartment side-panel lining removal?
I have the instructions 7003191. Mudman sent them. However, on page 3 there are 6 steps that must be done first, and I need those instructions. See attached (Mudman I am using your .pdf, thank you.)
Mudman please send Cayenne 2004 rear luggage compartment side removal trim panel please plz sir regards simon to sacwatt@iinet.net.au
Can you please send these details to me at pjkovach@comcast.net ?
I have a new map / stereo Porsche unit to replace my cd32.
I have a bad amp though and need to replace it and cannot see how to access it in the back
Thank you!
Thank you!
Received 1,149 Likes
Go here: https://rennlist.com/forums/cayenne-958-2011-242/
mudman2 could you possibly email me that instructions for trim removal on the Cayenne too please 70 03 19 thanks
shane.gomes@outlook.com
thanks
thanks
I pulled a tow package from a scrapped Cayenne and the controller is buried behind here
AllData does not have these instructions and it doesnt look like some of the above are active anymore.
There is a Rennlist thread on 958 that has pictures of panel removal and it is similar enough.
The short answer is to work from the top down. remove C pillar and D pillar and then it becomes obvious from there.
Panel stuff is SO tedious and I did see there are changes from year to year with fasteners so best to go slow
