Okay...seriously now, what is the trailer light fix?
#31
Originally Posted by ltc
MadFox, you're supposed to be watching my meds
(he's been slacking off lately...spending too much time at the Purplesaurus Rex punch bowl)
#32
Originally Posted by Bob Rouleau
Gotcha - too much is a short and too little is an open. Sounds like the designer did not think it through. A simple "learning mode" to normalize the expected current draw (within the limitations of the source current and fuse) would make a lot more sense. Connect the load, make sure everything is working, press the "learn" button and you're good. I think I understand your frustration. Thanks,
Welcome Bob..
p.s. now bob what model do you moderate at rennlist and are you a Cayenne owner or just a glutton for punishment "wanna bee"?
#33
Originally Posted by wingless
It is not a good idea to attempt running the 18 lamps through the Cayenne wiring in the existing configuration.
How do you know this statement to be true.
Is there a Resign the Forum procedure, or do I submit myself for public flogging? Would the decision be different IF (for Lewis’ benefit) I stated that I would enjoy that?
As Jphillips-998 stated in the initial post:
Originally Posted by JPhillips-998
Hooked up the S today. Turn indicators and brakes work. Running lights flicker very faintly.
The power to the marker lamps is switched through the circuitry in the trailer control module. At some point the current passing through the circuitry to the lamps will exceed what the circuit components can tolerate and they will fail. Also, at some point, the current passing through the vehicle wiring will exceed what it can tolerate and it will fail.
No, I don’t know where those limits are for the Cayenne, but I would not risk my vehicle if it were acting like JPhillips’ Cayenne.
I have watched PAG, PCNA, PCNA Technical Engineering Managers, PCNA Legal, Attorneys retained by PCNA, Porsche dealer technicians spend HOURS trying to resolve the problem, the whole time sitting back knowing they will fail.
Why would you modify a perfectly functioning trailer (i.e. hook it up to ANY other 7pin Pollack equipped vehicle on the planet (except for the Cayenne/Touareg....everything works fine) simply to make it 'work' with the Cayenne?
So, what you have now done is reconfigure the Cayenne to NOT (attempt) to diagnose bulb status (which, after all, was the intent of PAG's PATHETIC design implementation, but instead relay coil continuity....in other words if all of your trailer lights are stolen/blown out, you will have no idea, since the Cayenne only 'detects' the relay coil, NOT the lights, which was the original intent of PAG's design
What point is being made by objecting to the changes I’ve proposed?
IT IS IMPOSSIBLE FOR THE CAYENNE TO KNOW EXACTLY HOW MANY AND WHAT KIND OF TRAILER LIGHTS/LOAD HAS BEEN CONNECTED, SO THE 'DESIGNERS' ASSUMED A 'NOMINAL' LOAD OF INCANDESCENT LIGHTS....SAY AN OPEN TRAILER WITH 4 INCANDESCENT BULBS AND 2 MARKER LIGHTS.
The problem with the trailer is indicative of a more pervasive problem. Porsche ownership, in general and Cayenne ownership, in specific, require adopting several essential principals.
The first and most important is: RESISTANCE IS FUTILE. Another essential axiom is: FREE WILL IS IRRELEVANT.
The voices we hear in our heads are NOT random noise. This is the Porsche Collective. We are all connected to the Porsche Queen. She brings order where there was once chaos.
Any guess as to who is at the top of the list for assimilation?
#34
The power to the marker lamps is switched through the circuitry in the trailer control module..
At some point the current passing through the circuitry to the lamps will exceed what the circuit components can tolerate and they will fail. Also, at some point, the current passing through the vehicle wiring will exceed what it can tolerate and it will fail..
The two changes I proposed, to use a relay to switch all the marker lamp current, or to swap some marker lamps to LED lamps have negligible effect on the trailer lamp failure circuitry...
For a trailer with 18 side marker lamps, how many can burn out before the vehicle objects, 17?
What point is being made by objecting to the changes I’ve proposed?.
#35
Originally Posted by MadFox
Welcome Bob..
Bob is a very highly respected Rennlist member, moderator and PCA DE instructor.
#36
Still plays with cars.
I know, I know!! Me, Me, Me *hand in the air-jumping*
Porsche got an extra good deal on Lucas Electrics! Pass me that kool-aid.
Lewis, I was the GT2/3 and Canada mod until John gave me SUPERPOWERS.
My rides - 2000 Box S, 2002 GT2 with beloved PCCB, now a GT3. Oh, and a 430 for a bit of Italian spice. My wife is looking at Cayennes and I want a trailer to haul dirt bikes.. probably not enough bulbs to make the demon circuit work. On the other hand, I do have a hand-full of 10 watt resistors lying around. Perhaps a 55 watt backup light might help. More Kool-aid please.
#37
Perhaps, but since the trailer lamp failure circuitry doesn't work anyways, how do you define neglible effect
My experience has been that the side marker lights are visible in the mirrors. I use those to aid maneuvering in tight places at night. As such, I notice when they are not operational.
None, other than it seems odd to modify a trailer that works just fine with any other tow vehicle in the world to make it work with a Cayenne
The changes I’ve proposed do not alter a trailer to make it work ONLY with the Cayenne. So, the choice falls to each owner.
#38
At some point, Porsche may send down a series of “fixes”, to this problem that doesn’t exist. But, until then, the choice is to live with the problem or not.
1. Live with it.
2. Live with it not.
I prefer to with what's behind door #3, thank you.
#39
........ My wife is looking at Cayennes and I want a trailer to haul dirt bikes.. More Kool-aid please.
MadFox, Bob is a very highly respected Rennlist member, moderator and PCA DE instructor.
The Queen has just spoken to the MOST high pencil pushing drone and 2nd in command.. He has officially invited YOU to TOW a trailer with LED lighting upon delivery of your Cayenne of choice.... When (noticed we didn't say IF) you are totally frustrated, you will be invited to the DE (drive-in experience) at PCNA on Hammond street where members of this forum at 100K miles will meet and see their torched Cayennes smoldering in the lobby...
#40
Why do I get this mental image in my mind of a Rennlist Moderator meeting at John D's house and the discussion starts off something like this...
What the hell is going on in the Cayenne forum lately?
What are we going to do about it?
Talk of Purplesaurus Rex Kool Aid, T shirt designs with owners mooning PCNA, an overmedicated, vacation villa resident who we're not sure is a male/female/cat/all of the above trying to get the other Cayenne owners to storm PCNA HQ with flaming **** on a stick.
I'm not quite sure this is what John D had in mind when he invited us to join his forum.
#41
1. The internet is "wild and crazy" and thus can go "where none have traveled before..." (except in China (thanks google wimps) and Iran (need I say more?)
2. We're "bad" invites to the party.. We drank too much adult additive Kool-Aid and one thing led to another.. and presto by the end of the party... the drunks are naked in the den demanding Peter be put on a stick burning next to 100K mile set of Cayennes with two guys laughing their asses off in straight jackets.
#42
Mad - I don't think I am a Cayenne wannabe, I hate SUV's. On the other hand I also know about "happy wife = happy life", and besides I want something to haul dirt bikes around.
This forum is full of good info laced with a refreshing dose of humor. A tad sarcastic at time, but a few pointed barbs at PCNA et al are not only justified but good for them. There is a prevailing attitude of "vee can du nein wrongk" and that bubble needs the odd pin *****.
As for a DIE (nice acronym) on Hammond, I'm in. My Atlanta office is just around the corner on Peachtree Dunwoody. I can get us corporate rates at the Double Tree (Hilton). IMPORTANT, I have personally trained Jim the bar-tender to make world class Adult kool-aid. I'll bring a set of low mileage PCCB to throw on the bon-fire.
Regards,
Regards,
#43
I am pretty sure your "mental" image is purely that, I doubt I will ever be invited to Johns house for starters , secondly to assume someone would object to members exchanging non offensive banter with each other is part of what the board is all about.
Trying to use the board as a hammer to get PCNA to pay attention we know is futile, some still try but most take the subjective remarks as they are given.
I know my intake of your juice is no where near yours so the purple mist is not so visible, but I do appreciate the vintage.
#44
I see no reason why you wouldn't be invited to John's place. I've met him in person and he is a very sociable guy with a wikked (sic) sense of humor. Very articulate too.
PCNA reads these forums. I'd like to think that our inputs (if they can be called that) get some attention. I suspect something of the sort going on in the X50 transmission thread on the 996 Turbo board. Whoever "Dock" is, he seems to be related to PCNA in some way. Perhaps a lawyer watching for slandere <grin>. ltc, have you heard from him!?! The thread is an example of PCNA acting as the defendant, the judge and the jury on a warranty claim. By the way, is the Cayenne warranty invalid if you take it off road?
rgds,
rgds,
#45
rgds,
