need help rinding rotors
ok guys i found a place ,,its called nights auto ,they are selling zimmerman cross drilled rotors for 550 for bopth front and rear rotors anyone hear of this place ,,and zimmerman is oem rotors for porsche so it shouldn't void any warranties i hope this helps u guys
Are they drilled or cast holes?
Be careful with these types of rotors, as they can be prone to cracks forming between the holes. I would not use a rotor once the crack joins 2 adjacent holes......
The zimmerman rotors are drilled and not cast. At least that is what they are for the 951 and 944s. I will be replacing mine soon with non holed ones, although they have yet to crack with a number of heavy heavy days a sebring. On the cayenne you should be ok. What do you think ltc?
Originally Posted by Gator_86_951
The zimmerman rotors are drilled and not cast. On the cayenne you should be ok. What do you think ltc?
I've got 56K miles on original brakes WITH towing (don't ask).
Not really sure why you would want drilled/cast hole rotors on a Cayenne, but if you do go that route, I would just make it a habit to check for cracks, or perhaps even send them out for cryo.
Slotted rotors would probably be a bit better of a choice I suppose.
Besides, given your avatar, I'm likely to go along with whatever YOU say
Originally Posted by 996FLT6
Why would you use drilled/slotted rotors on the pepper? Regards. Mike
However, if I were to guess.........
1. They look cool
2. Reduction in unsprung mass aids in steering response.
Tom was correct in going with slotted rotors. I could also see cryo treating the rotors as well.
