Can PASM be added to a non-PASM truck?
I have been looking for a used CS for many months. However, I can not seem to find one with the options I am seeking. I did find one that has everything except for the PASM. Can it be added or am I better off to continuing my search? The other ride that I did find has PASM, but no nav or tow package, am I better off upgrading that truck?
Thanks,
Thanks,
Super Moderator
Needs More Cowbell
Needs More Cowbell
No, it can NOT be added to the truck, for a multitude of reasons, first and foremost due to the nature of the VIN specific wiring harness in the Cayenne.
On the other hand, it IS possible to add PCM/NAV to a CDR23 equipped Cayenne (it is sold as a standard Porsche Tequipment item) at a cost of approximately $4000
AND
option 1D6 (trailer tow option) can be added as well, at a cost of approximately $2000 (this requires removal of the rear bumper (to install mechanical tow bar unit) and rear passenger side rear cargo area surround (to install tow control electronics module....don't get me started on that)
I can not comment on the financial implications of upgrading adding PCM/NAV and 1D6 to an existing Cayenne, as I'm not allowed to handle my own finances....not very good with money... so I'll leave that opinion up to another forum member.
Good luck,
AND
Good luck,
Pepper Bartender
Originally Posted by curveraider
I have been looking for a used CS for many months. However, I can not seem to find one with the options I am seeking. I did find one that has everything except for the PASM. Can it be added or am I better off to continuing my search? The other ride that I did find has PASM, but no nav or tow package, am I better off upgrading that truck? Thanks,
a. part with a little more cash
b. not have to worry about all the '03 and '04 glitches
Now, if you're towing a big trailer with lots of lights, did we mention an annoying little problem revolving around a warning indicator... WHOOPS.. I had an out of body experience... I don't do tow light commentary... NEXXXXXXT - OH, ltc, ltc, are you there?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by MadFox
obviously if you're wanting to tow
Everytime I turn on my headlights, the trailer lights go out, the rear glass opens by itself and when I get out of the car and throw the remote control at the door, the headlights no longer get fogged up and my doors unlock.
See, works perfectly, no glitches
Grab a cup of Purplesaurus Rex and relax, this is like that bedtime story......
This bed is TOO soft.....translation: you have an insufficient number of trailer lights or LED lights (see ltc and JFScheck)
This bed is TOO hard....translation: you have too many trailer lights (see skl)
This bed is JUST right.....you have the exact number/type of lights Porsche guessed at...of course, this is documented NOWHERE in the known universe.
Man of Many Porsches
Arlen,
I would take the one with PASM, you can always upgrade the PCM( or get a better one) and the towing package. Find a CPO '04 or make sure all the TSB's are done. good luck
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by alex911s
Arlen,
you can always upgrade the PCM (or get a better one) ......
Exactly how many companies in the world are currently producing MOST headunits?
Let me see.....hmmmn, there's Becker (check) and then there's Panasonic Japan.....I remember now, yes, they tried to produce a MOST headunit for Mercedes S Class vehicles in Japan.....I'd ask them how that turned out after their trip to Germany for their MOST certification/validation/inspection, but I'm pretty sure those involved are still not willing to relive that experience.
Of course you can replace the headunit with just about anything you desire (assuming you can get a trim and mounting kit), but then you have to replace the amp, CDChanger, DVDNav unit, amplifier, run all sorts of copper wire in place of the plastic fiber optics, lose functionality of the steering wheel controls, explain to the vehicle's security/alarm system that the headunit really wasn't stolen....I'll stop there.
Sounds like a fun weekend project!
Originally Posted by ltc
Upgrade to a PCM better than the OEM Becker unit? Now THAT got my attention.
I saw sfbimmer's eclipse unit and lapiscayennes pioneer avic d1, both are touch screen and are more user friendly. They got it done here in the Bay Area, but like you said you will loose other functionality like steering button and security.
You guys are a hoot I spent most of the day reading about the kool-aid, by the way the revers engineering was great and I will be putting some additives in my verison... I have also read about all of the lighting issues and the back seat belt "upgrade" thing. It sounds like the best bet is to find something with the PASM and deal with the other stuff. Can I just add an aftermarket tow bar? Is the truck going to shut down or blow up or some crazy thing? I can live without the NAV, but towing with the PASM sounds like the ticket.
Thanks again,
Thanks again,
Super Moderator
Needs More Cowbell
Needs More Cowbell
You guys are a hoot
Psst, should we tell him about the "foaming at the mouth Defenders of the Cayenne Faithful"....those forum members who defend the Cayenne against all enemies? Nah, let him meet them on his own.....
I would also suggest checking out this past couple of issues of Panorama, as a Porsche dealer was advertising the tow package for $618 or so... good price, even with installation.
Yes, it will blow up
Yes, it will do multiple crazy things (I think the Cayenne has more personalities than I do....really)
Yes, but that is what gives the Cayenne its "CHARACTER"
Thanks again
They will definitely change depending on exactly WHAT you intend on towing.
However, Purplesaurus Rex Kool-Aid appears to be an effective antitode against long term Cayenne ownership.....however, I seem to have developed an immunity, which is why I find myself in a straight jacket, typing with a pencil in my mouth, in my "vacation villa", my Cayenne in the shop (out of sight, out of mind), heavily medicated (MadFox checks in on me from time to time and helps "adjust" my medications, and generally trying to make people in this forum laugh a bit, swear a bit, cry a bit......
Pepper Bartender
You guys are a hoot I spent most of the day reading about the kool-aid, by the way the revers engineering was great and I will be putting some additives in my verison... I have also read about all of the lighting issues and the back seat belt "upgrade" thing. It sounds like the best bet is to find something with the PASM and deal with the other stuff. Can I just add an aftermarket tow bar? Is the truck going to shut down or blow up or some crazy thing? I can live without the NAV, but towing with the PASM sounds like the ticket. Thanks again,
You could always just use a Garmon handheld GPS ... and U-Haul has real pretty towbars with orange stickers that cannot be removed with U-Haul all over them... looks classy at the PCA meetings. Oh, now regarding the forum guy formerly known as ltc now known as the "man in white with no arms" he was just kidding about the blowing up part.. that is only when you have a visitor from the middle east who is upset when you say "democracy" ... now shutting down is always a possibility - last one I heard of -- was this guy who was in west Texas on I-10 100 miles from the next exit... and his MTE reading in the dash was 0... sure enough it "shut down" -- outside of being "stuck on fuel STUPID" have never been stranded yet and don't know of anyone that has been.
