Engine specs
Old Jul 6, 2004 | 04:55 PM
slate blue's Avatar
slate blue
Default Engine specs
Hi guys do any of you have details on things like engine weight, valve timing and valve sizes? Also engine dimensions, that is size not bore *stroke.
Old Jul 6, 2004 | 09:49 PM
Jessa's Avatar
Jessa
Wondering if its fits? I'm bit curious myself, though its only a dream at this point...
Old Jul 7, 2004 | 04:06 AM
slate blue's Avatar
slate blue
You're good Jessa, what are you doing surfing over here anyway? Did you get lost? Go on back to the 928 Fourum and don't tell anyone about this!
Old Aug 14, 2007 | 11:41 PM
Vilhuer's Avatar
Vilhuer
After this many years any info on what valve sizes are in different Cayenne engines? Intake and exhaust valve diameter, lenght and stem diameter? Only managed to find V6 intake and exhaust valve diameters plus valve shaft diameter, 39.0mm, 34.3mm and 7.0mm.
Old Aug 15, 2007 | 11:29 AM
rombrigs's Avatar
rombrigs
V8 (non-turbo and turbo) -- Valve stem diameter is 6 mm. Diameter of intakes valves are 37.1 mm. Diamater of exhaust valves are 32.5 mm.
Old Aug 16, 2007 | 04:15 AM
99firehawk's Avatar
99firehawk
i can tell ya a cayenne v8 is at least 4 inchs taller then a 928 engine,
ive had em both out. you could make it fit but it wouldnt be easy
Old Aug 16, 2007 | 06:11 PM
Vilhuer's Avatar
Vilhuer
Thanks. So it seems six cylinder valves are much closer to what I'm looking for.
While visiting at Porsche factory few years ago they had Cayenne V8 engine pieces on display. Block itself looked much smaller than 928 block. It all extra stull like oilpan and intake that make it too large to fit into 928 engine bay. Strip all this excess away and I think it would fit with room to spare.
Old Aug 16, 2007 | 11:25 PM
JFScheck's Avatar
JFScheck
Just drop a Chevy small block V8 in it like in this month's Excellence magazine...
Old Aug 17, 2007 | 08:07 AM
Vilhuer's Avatar
Vilhuer
Small block conversions are too common. Why not use big block with 928 32V heads.
Old Aug 17, 2007 | 08:59 PM
99firehawk's Avatar
99firehawk
i think if you really tried you could make it work.
you would need to either rework the oil pan or the k member.
i think with some very short custom motor mounts you could stuff it in there.
we have one out at work ill measure it for ya tomorrow
