Firing up the Cayenne Turbo after 4 years, what could possibly go wrong‽
I've had the Turbo since new in 2004 and it's only done 55k miles. It's in reasonable condition so it's going back on the road until it dies or is regulated out of existence by future governments or fuel prices.
It's not moved for 4 years and the known issues to deal with are:
so what needs to go on the checklist?
- Flat battery. Should be straightforward.
- Snapped bonnet release cable because I was a clumsy oaf when I last tried jump starting. Remove wheel arch liner to get at it?
- Tailgate gas struts need replacing.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Drain the fuel if you haven't already done so, and refuel with fresh high-octane petrol
The following 2 users liked this post by BobcatBrian:
Petza914 (07-12-2024),
theworkerbee (07-11-2024)
Yes, drain and replace the fuel and fresh oil. I'd also pull all 8 sparkplugs and fog all of the cylinders and attempt a crank of the engine (after fogging) with the plugs still removed to get the oil pressure up, maybe crank for 20~30 seconds (starter may have froze while sitting). Cranking a completely dry engine like that could do Ring/Cylinder damage/wear, that is why you really should Fog the cylinders. Amazon or most major parts stores sell a Cylinder Fogging solution so you aren't just pouring straight oil into the cylinders.
theworkerbee (07-12-2024)
Yes, drain and replace the fuel and fresh oil. I'd also pull all 8 sparkplugs and fog all of the cylinders and attempt a crank of the engine (after fogging) with the plugs still removed to get the oil pressure up, maybe crank for 20~30 seconds (starter may have froze while sitting). Cranking a completely dry engine like that could do Ring/Cylinder damage/wear, that is why you really should Fog the cylinders.Amazon or most major parts stores sell a Cylinder Fogging solution so you aren't just pouring straight oil into the cylinders.
BobcatBrian (07-12-2024)
That's a good Fogging solution. What Petza said is true if you pour oil in the cylinders, you will want to cover the valve covers with a towel. The engine will crank easier and faster (higher oil pressure) with the plugs out. With the Fogging solution you may get a slight mist from the Sparkplug holes but not a lot as you would after pouring oil in. On a 90' V-motor, you would have to pour a fair amount of oil in at that angle to get the oil to the upper (intake side) of the cylinders, any less and you have to leave it dry until it coats the cylinders after a few cranks but any dry damage will then have already occurred.
I had a B4 Passat that I did not start for about one year. After a year it started right up and ran ok. Then I left it for two more years. Then with 3 year old fuel in the tank it would not start, not even a pop. I had to pump out all the old fuel which was bright orange colored and smelled awful. I put in some fresh fuel and it started and ran.
ekstroemtj (07-15-2024)
