Cooling Fans not working
Old 11-04-2023 | 07:51 PM
jl-p's Avatar
jl-p
Default Cooling Fans not working
Hi, i have a Cayenne s 4.5L 2003
My Cooling Fans are not working if the engine get to hot.
My Dashboard Water temperature meter shows the correct temperature . also via Torque and with my durametric cable the car knows the right temperature.
but its not engaging the fans.
But when i put my airconditioner on LOW LOW . both fans start spinning and cooling the engine.
fuses 1 2 10 and 12 are okay.
when i look into the wiring diagram i see that everything is controlled by the AC control unit
so that is able to control the fans but wont do it when the engine gets to how.
any idea where i can search. or what the problem is.
kind regards
Johan
Attachment 1371020
File Type: pdf
Old 11-05-2023 | 09:04 AM
Petza914's Avatar
Petza914
Most cars have a temperature switch in the cooling system to activate the fans. Don't know where it is in the cayenne but probably in a corner of the radiator (928s) or in one of the cooling lines (Audi Q5).
Old 11-05-2023 | 11:04 AM
jl-p's Avatar
jl-p
What do you mean with switch.
I checked the wiring diagram and dont know what you mean.
a physical switch a temperature based switch. or electrical like a relay.
Old 11-05-2023 | 11:13 AM
Petza914's Avatar
Petza914
A temp sensor that is a switch. When a certain temp is reached the switch closes creating continuity and sending power through the wires. Since your fans work with the AC on, the fans themselves are fine. If there's a cooking system temp switch and it's not closing, the fans won't come on. If you can find where that switch or sensor is, jumpering the 2 wires going to it should turn the fans on. If so, the switch is bad.
Quick Reply: Cooling Fans not working
