During replacment of the leaking cooling o-ring, I broke another part (3.6l)
I was replacing the "simple repair" of the oring and flange leaking coolant at the rear right of the 3.6 VR6, and at 180,000 miles i guess the little "Y" coolant line from the tank to the heater hoses, etc snapped.
I was able to get a "T" at a local autoparts store and make it work with clamps, etc to get home.
Looking for the part online, the "Y" is only sold on hose assembly 955 106 061 00 .
Has anyone gotten the "y" seperate? It seems pretty generic, and i dont need the whole hose assy, and it looks like a serious pain in the butt to change.
Take a look at this, try reaching out to FCP Euro and see if you can compare dimensions. Do you have a picture of the broken one?
https://www.fcpeuro.com/products/vw-...olf-1j0121087d
Mark
Mark
I am sure I have seen that elbow as a separate part somewhere, perhaps the Audi TT 3.6 parts catalog.
Mark is right on that part. I had the same problem you did and ended up replacing the entire hose assembly because I did not know any better. Then I realized you can get them from VW dealer, amazon, fcpeuro, etc. for a fraction of the price and much easier to replace. I bought one (genuine vw) from fcpeuro and replaced the one in my audi q7 3.6. Its the same part for cayenne, q7 and touareg.
Thanks for confirming, I'll have to replace mine eventually as I suspect just adding a bit of permatex coolant rtv to that leaky gasket will not last forever and the amount of heat in that area doesn't help plastic parts. I should consider replacing all of the coolant plastic but it's a slippery slope that never ends.
Mark
Mark
yeah the good news about the v6 models, is there is only like 5 weak points in the cooling system vs many more on the turbos. on the driver side by the alternator and under the fuel rail, there is a plastic pipe that is also prone to cracking. aka thermostat housing pipe. URO makes a aftermarket aluminum one. I just upgraded to that and it works well. Aliexpress has a metal Y piece that you need BUT the quality is not that great, so I just used the genuine VW one from fcpeuro. I figure for that price, I can replace it once every 10 years as preventative maintenance.
Thanks for the tips. Are the potentially leaky oil cooler o rings by the oil filter housing? Is it best to change them when doing an oil change or do you not loose much oil?
Mark
Mark
Yes I did mine when doing the oil change. The reason I do that is because the oil system is opened up and just in case any dirt, etc. got in. Also it was time for a oil change anyways. Now the oil filter housing O Ring is different. It looks like a "8". That O Ring looks hard to do, so I skipped it. If anyone has tips or DIY, please send my way. It looks like on our 3.6, the oil filter housing oring is built into the motor mount bracket and getting to those bolts do not look fun. The oil cooler housing looks like a square with fins and its a 36mm if my memory is correct. Now they did redesign the oring so it will look a little different than the one you are removing. The new one has 2 "ears" whereas the old one has like 8. I guess vw saw the complaints and revised it.
Mark
Mark
just got it in the mail, fits perfect.
