Easy fix for fogged-up windows: code 1596, servo motor for fresh air circulation flap
The windows in my 955 Cayenne Turbo kept fogging up in very cold weather and were slow to unfog.
After a diagnostic scan with an iCarsoft, I found code 1596 (servo motor for fresh air/air circulation flap) — the fresh air flap wasn’t moving. I confirmed this by looking at the live values of the servo.
I followed the procedure for air cabin filter replacement — the servo motor is right of the air filter, connected to the flap with a white plastic arm. I unhooked the arm, wiggled the flap loose (it got stuck somehow)
I verified that the servo worked (visually with the arm disconnected, then with scanning tool looking at live values)
15 minute fix, $0 spent.
No more fogging issues afterwards!
I have iCarsoft and don't remember ever getting to that screen. I think I would get a communication error when I tried to read anything for HVAC.
I don't want to go too topic but I'm wondering if my iCarsoft is set up right.
Do you find the automatic mode to be useless and a waste of time? I have to always go through each system one by one.
You can update the iCarsoft (download the new firmware from the website, copy it to the SD card) — it seems to fix a lot of bugs.
I use the manual scan; the automatic scan doesn’t really seem very useful.
Hmmm, it has been a few years since I last checked for an update. Worth a shot, thanks.
btw, I recently had a fog to my windshield after starting off (cold weather also) and it turned out it was my sunroof drains* leaking near the footwell.
I had done my cowl drains but never did locate the sunroof drain plug things. Just a thought in case your fog ever returns inexplicably.
Sounds like you nailed it with the fresh air door thing, though.
Thanks.
*truth be told, I still haven't verified the source... I'm using the process of elimination. I also haven't checked my AC drain, but I'm under the impression that that only deals with water when the AC is on.
Thanks.
Thanks.
Thanks.
