Cayenne base rear air suspension
Hi Everyone,
My 2008 has a slight "nose up" stance at the best of times. I want to tow our boat with it but this makes the rear squat even more. I was wondering if it would be possible to fit air suspension to the rear only, either using an aftermarket kit or by utilizing stock parts. Any other solutions?
Doubt you could do half the OEM setup. Probably needs to be an aftermarket kit. I'd contact Arnott and get their input.
5l32v4c (08-06-2021)
Hi Everyone,
Cheers,
Tom
Hi Everyone,
if your Cayenne rides nose up even before towing then you might need to check if your current springs are sagging/worn out. New set of springs/struts might be all you need
Other option would be to get OEM heavy duty springs that are designed to handle extra 200-250 kgs per axle and pair it with bilstein B6 shocks. They will ride "sporty" under light load.
Part numbers for springs;
955-343-533-81-504 (front)
955-333-531-11-504 (rear)
I have a lightly used heavy duty springs set for sale, hopefully not violating sell rules
