Cayenne Turbo 2005 Rapid Crank, No Start.
Hi,
My Cayenne Turbo 2005 was overheating. Decided to replaced the thermostat, since no visible leaks were observed and also decided to give a proper tune-up
Changed the thermostat, gaskets, some cracked vent lines, all 8 spark plugs with new coils, and the annoying oil level sender...
When everything was set, I tried to fire-up the engine and has a rapid-cranking but won't start. The rev gauge moves to near 800 RPMs but nothing... Check the fuel rail nozzle and had pressurized gas or petrol (whatever want to call it)...
I put the Durametric tool and gave me all the Ignition Coil Codes (P0351, P0352, P0353, P0354, P0355, P0356, P0357, and P0358 Ignition Coil No signal/communication). Funny thing is that I clear these codes, the Cayenne starts and runs for 3 to 5 seconds and dies and the 8 faults returns. Reset, dies, faults.
Check all fuses and are alright. Battery was fully charged, drained, and re-charged. Perform the alarm-key close-open for the immobilization thing but nothing.
I checked all connections that I removed and were found connected properly. Disconnected the battery for several minutes and the same: dies and 8 faults.
Ran out of options...
Thanks in advance.
Thanks in advance.
19psi (07-28-2020)
The other thing that could cause misfires on all cylinders and not just one bank is the crankshaft position sensor. We're you near the wires or sensor for that. I don't even know where it is on the Cayenne.
Eilenberger's Law of Troubleshooting: "Look where you last worked"... IMHO - something's up with the ignition system. Right coils? Right plugs? As for why it starts for 5 seconds then shuts off - the ECU shuts off fuel to any misfiring cylinder to keep from flooding the cylinder.
Return those and get proper parts.
https://www.e46fanatics.com/threads/...-coils.462032/
https://maxima.org/forums/dealership...ff-artist.html
But Petza914, the name sounds German! They must be good!
More great reviews of Hamburg-Technic:
https://rennlist.com/forums/993-foru...g-technic.html
https://www.bimmerfest.com/forums/sh....php?t=1030617
Yeah. And if you bought 20 then you would have 20 bad coil packs.
