I always had good luck with Rustolem "Clear Coat for Plastic" on Headlights but it is now discontinued. I tried the "2K Clear" on Amazon but it went on really thick.
You might try hand sanding the clear you already laid down. 1k, 2k, 3k, 5k grit. Then DA polish it and put a hydrophobic UV protectant on top. Takes about 30 minutes per light and might turn out real well.
They look great. I've been putting it off. Did you hand-sand them?
Yes, I spent about 2 minutes with each grid per light. But when I polished them I used a hand power drill with Mother’s Mag and Aluminum polish on a buffing pad. Finally, I sprayed with a clear coat.
