So odd, headlight R&R then Front Side Light Error
Old 02-26-2019 | 01:37 AM
RSbob's Avatar
RSbob
Default So odd, headlight R&R then Front Side Light Error
Removed and reinstalled the left headlight making double sure the harness connector was snug. Immediately after starting I get a Front Side (marker) light error. WTF? Jump out and sure enough the bulb is not illuminated. Thump the fender next to the marker light and it immediately illuminates. Have had no issues with the side light up to this point. How in the name of all things is there a relationship between a bulb being out after installing the headlight and thumping a fender and having it go back on? I didn’t smack the fender super hard enough to shake the headlight assembly, so what’s up here? Another bizarre Cayenne anomaly?
Old 02-26-2019 | 03:40 AM
John McM's Avatar
John McM
Our left headlight has intermittent issues as well. When it alarms we get out of the car and give it a push inwards. We replaced the light carrier and it now does it less often but it’s not fixed.
Old 02-26-2019 | 10:54 AM
Petza914's Avatar
Petza914
Being a 914 owner, I assume you have a can of Deoxit D5 spray in your cabinet. Remove the bulb again and spray some Deoxit in the socket, and wipe it with a pipe cleaner. Do the same to the bulb contacts. Your problem should be resolved. Removing the headlight caused you to pull on the wire harness that the side marker bulb wiring is also a part of and you've created just enough of a bad contact where the light thump caused the contacts to touch again, but it won't be a stable connection and will keep happening. Also, if you've recently replaced one side marker bulb only, Porsche bulb control modules are very sensitive to difference on the 2 sides of the car. If you replaced one bulb, but another of the exact same bulb as you installed and replace the other side with it (Deoxit those connections too). If you don't remember the brand and type of bulb you used, buy a new pair of the same and install both.
Old 02-26-2019 | 12:41 PM
RSbob's Avatar
RSbob
Thanks John and Petza. Deoxit it is.
Old 02-27-2019 | 05:34 PM
bluetoff's Avatar
bluetoff
4th Gear
I had a similar problem after fitting new side light bulbs. I managed to sort it by spraying the block connectors with electrical cleaning spray. Never happened since.
Old 02-27-2019 | 10:56 PM
RSbob's Avatar
RSbob
Speaking of 914s, if you receive the PCA weekly email, check out this weeks Car of the Week. Look familiar?
Quick Reply: So odd, headlight R&R then Front Side Light Error
