Ugh more Android problems (bluetooth)
Old Feb 26, 2019 | 01:07 AM
dcapper's Avatar
dcapper
Default Ugh more Android problems (bluetooth)
Has anyone had issues with their Android head unit bluetooth not working? It syncs all the time with my iPhone but no audio or microphone when I make a call. Is there something I'm doing wrong?
Old Feb 26, 2019 | 10:49 AM
Petza914's Avatar
Petza914
Do Android head units actually work with Apple phones? Seems like the BT profiles might be different. To use an iPhone, don't you need Apple car play or something like that? I can't help much more than posing that question as I don't own a single Apple device.
Old Feb 26, 2019 | 11:39 AM
dcapper's Avatar
dcapper
Thanks! Would something like this work?
Amazon Amazon
Old Feb 26, 2019 | 11:46 AM
Avec's Avatar
Avec
My Iphone works fine with the Android head unit. In fact, I don't automatically connect because I don't like it taking over the call. There may be a setting in the head unit regarding phone calls.
Old Feb 26, 2019 | 11:47 AM
Petza914's Avatar
Petza914
https://www.amazon.ca/ATOTO-AC-CPAA4.../dp/B07G17FWPV
From the Q&A on that product, it looks like it will work as long as you can download the Autokit App or APK, so I'd go to the Apple store and try that before buying, but if you can get the app, then I think it will work for you.
Old Feb 26, 2019 | 12:31 PM
dcapper's Avatar
dcapper
I have the setting not to auto answer but when I make a call or try to receive a call it will connect but no audio or microphone. I'm wondering if I just need that app or just buy the Apple carplay. I will try the app first but I wouldn't think I need an app to use bluetooth to answer a call.
EDIT: I don't care if I can play music from my iPhone. I just want to be able to make and receive calls.
Old Feb 27, 2019 | 09:12 AM
Avec's Avatar
Avec
One thing to check is head unit volume - Yeah, I know, sounds stupid. Different things on my head unit have different volume levels. For instance, when I blue tooth music or pod casts from my phone, I need to turn the head unit volume way up to hear. When answering the phone, the volume is fine. Maybe yours is reversed
Old Feb 27, 2019 | 09:31 AM
Petza914's Avatar
Petza914
If you look in the manual that came with your head unit, there should be a setting for volume compensation for the different inputs or outputs so you don't have to do that. It should have one set as a baseline (maybe the FM tuner ) and then let you raise or lower the volume of the other inputs (CD, BT phone, USB etc) to match that with a compensation factor.
Old Feb 27, 2019 | 10:09 AM
dcapper's Avatar
dcapper
I'll look at that tonight. I ordered Apple carplay yesterday from Amazon. Maybe that will help too. I'll post my findings.
Old Feb 27, 2019 | 03:58 PM
Avec's Avatar
Avec
Mine didn't come with a manual, but I will check Seicane's website to see. Sounds exactly like what I need
Old Feb 27, 2019 | 06:49 PM
VulcanGrey's Avatar
VulcanGrey
Mine works fine with the bluetooth for audio and calls from my Android. Audio has worked with my gf's iPhoneX as well the few time we've tried.
