Ney Keyless Remote - Why can't we use a pre-owned one?
I have a LIKE NEW Cayenne remote that I got from a buddy, same part #, everything. The dealer is telling me I can't reprogram it. Once it's coded that's it. I was going to have the local locksmith cut a new blade and use the remote, but apparently our only option is NEW for $500+
is this true???
is this true???
I don't think the case cane be opened up without being destroyed or significantly damaged - it's all glued together with some strong epoxies in the case of the Cayenne fob. You can find some videos on youtube.
Just about the only thing you'd be able to salvage would be the button covers (including the red one on the side that likes to fall off after a while), as these do wear over time.
A few months ago I lost (mislaid!) one of my keys for my 2009 GTS. After a couple of weeks being unable to find it, I took the plunge and ordered a new key. With only one key, I was scared of the effect if I mislaid that one as well.
When the new key arrived, the dealer took my remaining old key and the new key and coded them both (with a new code) to the car. So the old key was recoded!
What the dealer does appear to have the facility to do, is to remove a key permanently from the system. In the event of a key being stolen or permanently lost, then the system can be instructed never, ever to recognise that key again. Apparently that instruction can never be overidden.
As an aside, $500+ does seem high. My new key was £305 (currently about $366) including the coding, and that includes our UK VAT tax of 20%! £254 without the tax.
peppapig
I am not sure that that is strictly true.
peppapig
peppapig
BIG difference between that and any odd one off ebay or wherever.
The difference here is IMPORTANT (before people go on ebay buying useless key fobs) - the OLD KEY that you had matched to the car was NOT recoded. What did happen was the dealer told the ECU to recognize a key which had originally been coded to that ECU and that VIN#.
I would add that I subsequently found the other original key and the dealer said that they could do nothing with it. When the new key and the other old key were "made to match" the car, the key that I 'mislaid' was eliminated from the Porsche system. It had become merely, to use their words, a paperweight. They could do nothing with it!
Furthermore a decision was later made to get another new key because I liked the idea of having a third key. When that key arrived from Porsche, all the keys (except the previously mislaid one) had to be at the dealer at the same time to have "something" done to them. The dealer described it as coding them.
peppapig
When the remotes are coded it doesn't matter if they are previously used or new. The ebay remotes work fine. I have programmed quite a few. When remotes are coded all that will be used must be present as they are all unpaired and repaired to the system. You don't just add a remote, you program ALL the remotes.
Super good point. Thanks!
When I bought my 2005 used it only came with the valet key. A couple of weeks later the used car non-Porsche dealer I bought it from sent me two blank blade key fobs. Local dealer does not have a key cutter. Told me if I could get them cut they would "try" to pair the new key fobs for $140, but have not had much luck getting them to pair. Checked several local key makers and none could copy the valet key to open the door so did not trust them to the blank remote keys. Since no-one could cut blanks went ahead and bought the $500 key thru Porsche. Still have the blank key fobs.
In the last "key" thread, you seemed to say that you had been able to, and I asked you about that. Don't know if you didn't see it, but you didn't respond.
https://rennlist.com/forums/cayenne-...-straight.html
Post 6 is where I asked.
I do understand there is a capability in the Car's system to accept one remote fob as an emergency, but this can only be done once and doesn't start the car, because it doesn't have the chip coded to the vehicle.
A lot of this was covered in the other thread. https://rennlist.com/forums/cayenne-...-straight.html
Not sure on this... everything I have seen in researching this, and confirmed by two local dealers, is that when they request a key from Germany, the Chips ID is assigned to the VIN.. with out this in place my understanding is that they cannot just code the key to the vehicle at the dealership. It needs verification through the Porsche System (not just the car itself)
There is some aftermarket software that will program Porsche keys. Those utilities are very expensive and usually Porsche specific. Unless you are a smith who does lots of Porsche then its not likely to be had, it just is not cost effective for the limited number of Porsche customers most smiths will see.
The biggest problem with the Cayenne is the abundance of misinformation and horror stories, and the lack of published tech info, diagnostic software, and fact.
These two points are mutually exclusive.
Peppapig has direct, first-hand info to his. Deilenberger, did you go through the key recoding processing and have a different result? The fact that Peppapig was required to have all keys present (and presumably the car) would indicate that all keys, and the car are REprogrammed simultaneously.
Thanks for the extra Detail in explaining your situation.. its not something many on here take the time to do, and it makes all the difference.. The fact that you have access to PIWIS puts you in a very small percentage of us Enthusiasts who don't have the privileged to access that system and that explains a lot about what you've been able to accomplish.
Sounds to me, for those looking to add or replace keys and save a buck, having a dealer/tech that is willing to cooperate and try something that the Manual and the Mothership say is a no-no will be the linch pin to success.
From a business stand point, I understand Porsche's position on the parts origins, and their willingness to work with them or not... it's liability and self preservation along with getting paid for your R&D and technology... I get it, doesn't mean I love the price tag they have assigned to it all.
MK
