Transfer case changes into low 4 by itself?
955 cayenne 04 200k
Went to park car and changed lever from D -R.
gear box got stuck in N for a brief moment and then transfered into low 4.
Now won't come out of low ****!
Reference your manual, but I think you have to back up in reverse some distance as part of the process of disengaging 4-Low.
You need to be in neutral, and pretty much stopped with your foot on the brake to engage or disengage the low-range via the dash switch. Make sure you're satisfying those requirements. If so, something having to do with the engagement motor and/or its wiring has a problem.
Maybe if he's got a Ford Explorer from the 90's, backing up would help!
When I was buying my 957 TTS and rode with the Porsche dealership Tech during the PPI, he tested the low range mode and backed up after changing out of low Range before proceeding forward in normal mode. Do with that info what you'd like, but maybe its extra insurance that nothing was binding and stuck in low range or maybe it's completely unnecessary - I don't know.
