Recommended PSI with 22" Wheels?
I'm curious to know what PSI I should be running with 22" rims? Stock on the CGTS was 21" and it recommends 39PSI Front and 49PSI Rear. What are others running with 22" wheels?
TIA!
-Andy
TIA!
-Andy
yes. It’s in owners manual to increase rear when towing. But it’s also dependent on driving style what you see in tire wear as long as you are within tire manufacturers recommended zone.
I run the same recommended pressures on my 22"x12" as for the OEM 21" tires and as I recall, there is a 5 or 6 psi difference front to rear. I usually have them set for the fully loaded vehicle pressure as our Cayenne is primarily used as our family trip vehicle with a roof box, full luggage load, and all 4 of us in it.
