NGK or Denso plugs
NGK or Denso plugs
Looking to renew the plugs on my 2006 CTTS.
I know that Beru are the OEM but have also seen:
NGK PFR7Q
Denso IK20
The Denso are the cheapest at about 60% of the others - has anyone else run them in a CTT or CTTS successfully?
NGK PFR7Q
Denso IK20
I did the NGK's as well in my CTT; after swapping got between 3-4mpgs better. Can't say there's been any performance improvement though. Make sure you get the right ones; there are some for the 957 that are very similar but a quarter-to-half inch longer. Check my other posts for more details...
Hi Dilberto, aren't the NGK BK7REQUP multi electrode plugs?
I thought the CS could use multi electrode but the CTT and CTTS were supposed to use single electrode?
What gap, I'm buying a 08tt, Tune & secondary cat bypass....
I used the Denso plugs on my CTT and have been very happy with them. These plugs will work just as good as the more expensive offerings. No reason to spend more if you don't have to.
This will vary depending on what kind of spark plug you are using. Denso told me to use 0.040" for my PK20TT spark plugs. You can go to their website http://densoautoparts.com/ and plug in your vehicle's information to get the gap information for which type of spark plugs you plan on using.
I'm doing them, I think there 22, I've now seen many happy with them & many unhappy with stock, that's why I looked into it
http://www.globaldenso.com/cgi-bin/g...&action=search
