Did I buy a lemon? 08 Cayenne S, need help
#46
On the “sleeving” repair, the replacement piston rings may not “ wear in” properly if using a steel liner and stock piston rings. I know someone who attempted this on a modern Audi. The rings never seated and he ended up buying a replacement short block from Audi. Would be interested in knowing how the Russians got around this.
#47
Everyone on here is spot on. The fact that two plugs were oil fouled in less than 200 miles is pretty damning. They show no signs of preignition detonation or running lean which are the two cases that would melt your piston.
Do you have the ability to stuff a borescope down the plug hole and verify for yourself that it is indeed a melted piston? If they are wrong about that, then I think you have a legit chance of proving their incompetence and/or bad intentions of selling you a car with a scoring issues. You do have a leg to stand on if you can show that it is a scored cylinder and not a melted piston (which we are all pretty sure you will find.)
Go get a $25 scope on amazon and check it out. You need to take matters into your hands one way or another here or they are going to double screw you over.
#48
Before you hire a lawyer, check what the dollar limits are in small claims court in NC. If they are in the ballpark of what you might recover, and assuming the dealer is not being cooperative, that would typically be the way to go. Legal fees, likely $300 per hour+, can chew up a lot of money in a hurry. A lot will depend upon the competence of the judge, but small claims court judges are typically truth seeking and try to get to a fair result.
#49
Received 1,140 Likes
Why there was a misfire to begin with? The seller changed the plugs - did they break the engine by doing the work on plugs? Actually, the answer is no - it was broken before the seller got it. But if you have a misfire and big oil consumption - it needed the new engine anyway melted piston or not.
The wisdom on Russian cayenne forums is to sleeve the engine in case of scored cylinders - that creates an engine that will last a long time. But there are people who are experienced in the process - I don't think that many cayennes in US\Canada had engine sleeves installed. Cost is about 10k$
#50
There are also some shops who are using Fiat sleeves, some BMW piston, some Toyota parts.
#51
Sorry to hear about your misfortune. Many have offered really good advice. One more tip- if you EVER get a flashing CEL, pull over and shut the engine down immediately. It means that there is significant risk of catastrophic failure. Driving on a flashing CEL is really, really bad idea. The Porsche dealer gave you terrible advice.
I hope you get it sorted out to your satisfaction. My hat is off to you for your calm demeanor!
Cheers,
TomF
Cheers,
TomF
#52
Thanks, TomF I'm stressing about the financial implications, for sure.
Everyone, here's a pic of the piston from the seller's borescope. This was taken last Saturday. Thoughts? Seller remains insistent that the piston melting would be caused by driving on the misfire. I'm unsure. Most important thing really is a cost-effective solution.
#53
Without getting into details who will pay for it. I see following options to get this cayenne back on the road: We also not sure what state the engine is in. But assuming damage is limited to just 1 piston and cylinder walls are scored:
1. Used engine from eBay.6-10 grand
2. Use 928 that @deilenberger mentioned to rebuilt the block and then rebuilding the engine with new pistons 8-10 grand
3. Use some race shop to rebuild engine using sleeves - 8-10 grand if done right - you may get the special cayenne that will last a long time.
#54
Thank you. Interestingly, the seller is offering to try to sleeve it. The main mechanic has done it before, but not on a Cayenne. Not sure what charge they'll propose. Given the current engine seems done otherwise, is there any risk beyond opportunity cost of paying a lot more to have someone else do it?
#55
Also, any chance older model engines fit into the 08 Cayenne? I know the older ones weren't direct injection, but do they fit in the 08? I bet not, but I'm grasping over here!
#56
You will have to be the Project Manager & QA on this and inspect, question and document everything. Ask what warranty you will get on this work.
#57
Fit? Maybe. Work - no. Too many differences and different computer control of the engine. You need a same era engine. Quite a few pop up on Ebay - from $2k-5k (depending on condition and miles and what they leave on the engine like alternator, AC compressor, etc.)
#60
