Just got an 08 Turbo
Congrats. Take good care of that panorama roof.
Looks great. Can't tell if you have the metal skid plate trim package from the views you posted, which looks great with the silver trim package you have, but I have the front skid plate and complete deeper/lower rear bumper from Turbo S with matching plate for sale in the Marketplace if you want a more aggressive rear look.
Yes, you must be like me - mod parts ordered before the vehicle even arrives - here's the link to the add with photos and info.
https://rennlist.com/forums/parts-marketplace/1028130-cayenne-front-and-rear-facelift-kit-turn-your-base-or-s-into-turbo-look.html#post14515221
https://rennlist.com/forums/parts-ma...l#post14515221
Which Bluetooth hook up are you doing?
Does it have Bose? If so, you'll need to get an optical to digital solution to run the amps and sub. Or, you'll have to put in new speakers and run wiring to the speakers. I see MOST has an adapter but from what I understand you lose either balance or fader control as it is two channel. Not a deal killer, just keeps you from fine tuning. You could alsp put in an iSimple hard wired bluetooth adapter either FM modulated or wired to an aux in (if you have one). I am thinking of the hard wired iSimple that uses FM modulation.
I know Becker can do an AUX in if your radio doesn't have one but it is mono only. Toss up between true hard wired connection at mono or FM modulation (albeit with a direct antenna connection so no static).
