Boxster & Boxster S (986) Forum 1996-2004
Engine rebuild equipment -use your wife's ...
Old 12-08-2014 | 08:50 PM
Schnell Gelb's Avatar
Schnell Gelb
Default Engine rebuild equipment -use your wife's ...
oven. Ex-wife if she reads this?
Yes,you've done all the mods and machining to your crankshaft.You've cleaned it many,many times.You've inspected every surface using jeweller's glasses ,measured every journal on at least 3 axis .Now one final rinse in the parts washer.But what about any residual moisture in the oil-ways ?
The M96 crankshaft is a perfect fit in your wifes oven. Set it to 'Drying' & convect at 180 degrees F for 20 minutes .Allow to cool and seal in stretch wrap. I wonder if Raby uses this tip in his rebuild class?
Oven roasted M96 -yummm
Old 12-08-2014 | 09:01 PM
Macster's Avatar
Macster
Hope you oiled it well before sealing in plastic or its going to rust. Rust on a crank equals large unwieldy paper weight.
ltusler's Avatar
ltusler
Jake would have cleaned the oven first!
Old 12-08-2014 | 09:06 PM
Schnell Gelb
Macaster,
Yes, lots of clean oil.I use newspaper saturated in oil before the Saran wrapping. What a lovely mess. Fortunately this is S.California so humidity is low -but I'm taking no chances.
Old 12-09-2014 | 01:21 AM
Flat6 Innovations's Avatar
Flat6 Innovations
Former Vendor
And I wouldn't have lined the pan with a chunk of Kevlar!
Old 12-09-2014 | 01:24 AM
Schnell Gelb
Check back tomorrow -I'll show you roasted crankcase half ! Yup,it just fits ,but you have to be real careful with the temperature otherwise it becomes sticky and runny -not good?
Old 12-09-2014 | 05:47 AM
Stephen Tinker's Avatar
Stephen Tinker
The crankcase half won't be the only thing that is sticky & runny if our wife catches you in the act....
Old 12-09-2014 | 10:34 AM
extanker's Avatar
extanker
as a hardcore harley owner,the dishwasher,oven and living room are all fair game for engine repair. you will need an understanding wife. be advised ovens have been destroyed by everlasting odors after this use
Old 12-09-2014 | 12:50 PM
ltusler's Avatar
ltusler
If you get caught, offer to clean it after you're done, that should make it better.
Quick Reply: Engine rebuild equipment -use your wife's ...
