Boxster engine woes
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I just recently bought a 1999 base 986 with 97k miles. The seller stated it had an ignition problem, which was true, but he carefully omitted the fact it had a blown head gasket as well.
I see no evidence of coolant in the oil, but when I pour coolant into the reservoir it flows right out of the exhaust manifold.
The way I see it, the best thing I can do at this point is part the car out. Anyone interested in a complete motor that needs gaskets?
Justin
Justin
The engine might just need a head gasket. 'course, the leak could be due to a cracked head or even a cracked block.
Up to you but you might want to put some more time -- and involve an experienced Porsche mechanic -- into better diagnosing the engine's true condition. It might be salvageable for not an unreasonable sum of money.
Justin
Justin
Boxster engines do not blow head gaskets so I'm guessing you have a cracked cylinder & therefore a $3,000 car. If I were you I would try & force the seller to refund the purchase price. If that will not work post your car on 986.com forum for more exposure.
Former Vendor
It doesn't need a head gasket.. A crack has formed within the head and through one of the exhaust valve spring seats/ exhaust ports. OR you have a cracked cylinder/ D chunk failure.
I have NEVER, not once EVEr seen an M97 blow a head gasket. The MLS head gaskets are stronger than the cylinders or cylinder heads.
I don't think its a D chunk failure, because every so often, when the ignition switch cooperates, I can get the motor to turn over. I drained the oil and did not find any evidence of milkshake. Thanks for the info fellas.
Needing a new head doesn't read like the end of the world.
OP: maybe you should look into what a head replacement job would cost?
I think I will just part it out. Its not been loved for some time, not the best respray in not in the original color. I mean ive located a used motor for 3k in a parts yard. But when its all said and done I still only have a 7k dollar car... I just hate to do it because its JUST nice enough you know.
If the car is in otherwise pretty good shape, it can make sense to fix the car.
But if the car is just not that good overall…
I'm not a fan of parting out cars. It can be a drawn out process, and to be a plain old pain in the butt task.
My inclination would be if I'm not going to fix the car and get it back on the road to just sell it, in this case with the engine sick probably to a business that buys cars in this condition to support its used/salvaged parts business.
One gets rid of the car in one fairly simple transaction and can move on. I mean I'd hate to every time I walked into the garage see the remnants of the car there reminding me of things I'd rather not be reminded of.
