Supercharged!
Hey guys. I have an Imagine Auto Supercharger kit on my 1999 Boxster, it was there when I purchased it this year , not sure when it was installed. With 37,000 on the clock when I purchased this year I have been going through all the routine maint (car fax shows regular service reports, but no detail on what was done).
Spark Plugs are next on the list , I did all the research , got everything all ready and got on with it. The drivers side while tight, with the wheel and panel off , you get pretty good access, fine...
Passenger side, well hello Supercharger , right in the way of changing spark plugs!
I really dont see any way at all to get the the one closest to the rear , and the other two are pretty obstructed, forget about getting tools in there!
I pulled the drivers side, they were all in pristine shape, I am assuming they were all changed at the super charger install.
Does anyone else have the Imagine Auto Supercharge? If so , any suggestions on HTF you change the plugs on the passenger side where the Super Charger is mounted!!!
Wax On, Wax Off
Use the basic principles of working on cars. you need 2 things, and lots of both.
1)brute force
2)ignorance
When one stops working, start applying the other. eventually the job will get done.
1)brute force
2)ignorance
I believe the charger has to be removed....
imagine auto is gone but the main guy/probably who installed it back then is still around...search...i forget his name
PS.....from what I can see of your pictures, that is not an imagine auto supercharger kit. This is what ours looked like. We utilized a Procharger self contained blower.
Thanks Doc , the options list when I bought the car from d and m motorsports said aftermarket supercharger , imagine auto .....guess they were misinformed !
Anyone recognise this hose? I think it is from a Imagne Auto supercharger kit.
Not being as auto mechanically savvy as most here I have a question. I thought a supercharger would be belt driven and yet this looks like a typical exhaust turbo.What is the area to the left of the turbo looking piece connected to ?
A recent blog post of mine, better shows the front of the supercharger/belt assembly.
http://rennsportkc.com/986-boxster-s...er-comes-home/
