10J x 18 ET58 - someone with experience please
Hi all
After spending hours with various offset calculators I'm almost there, but would really like someone's advice, who's done it:
I've just bought a set of Carrera III alloys:
Fronts: 8J x 18 ET 57
Rears: 10J x18 ET58
My current Turbo twists are:
Fronts: 7.5J x 18 ET50
Rears: 9J x 18 ET52
The car is a 2001 Boxster 986 3.2S
What I'm trying to work out is the size of Spacer required at the back - I currently have a 22mm and whilst it easily clears the strut, the tyre does stick out of the arch slightly.
The research I've done suggests a 15mm or an 18 mm spacer will be perfect, but not having the luxury to try before I buy I don't want to make a mistake and I'm finding mixed results re. rubbing - whilst the 18 will definitely work, will the 15 tuck in slightly without rubbing on the strut? I'm getting confused!
Cheers
Rears: 10J x18 ET58
Rears: 9J x 18 ET52
Cheers
11 mm would be ideal I believe. The 986 with an 18 x 10 should have a 47mm offset, at least that is what I came up with. So the 58 should be perfect with an 11 mm spacer. 22 would definitely make it stick out a little. The 22mm spacer would make an 18 x 11 work nicely I think. If you decide to get smaller spacers I might be interested in your 22s.
Not to high jack the thread but I just came on to ask a similar question. I want to put... Fronts: 7.5J x 18 ET50
Rears: 9J x 18 ET52 Turbo Twists on a 2001 and was wondering what spacers to use. From what I understand you only need 18mms in the rear. Is that correct?
Tim
Tim
Would it be useful/possible to make a template spacer out of 3/4" [19mm] and/or 1/2" [13mm] wood or aluminum? Test for fit/rubbing, etc. If wood, can plane it down some, and test again.
Obviously don't drive on them ...
