boxster s radio code- Found, but i dont have sound!
Hi, id like to know if i can get my radio code with the vin number at the dealer?
or i need to remove the radio?
any help would be appreciated
thx
thx
If your radio is any of the models included, you should be able to obtain your
radio's model number and serial number from the instructions shown in this link
without removing from the dash.
https://rennlist.com/forums/7189538-post6.html
If you would like to post both the model number and serial number here,
I'll be delighted to provide your radio code.
Cheers
You should also be able to obtain code from dealer, but if it's any of the models that I
can provide through serial number, I'd feel so much better, if you get it for FREE also at
the dealership.
I have provided code for model CDR-220 before. Unfortunately the number you've quoted is not a
Becker serial number. Has this been derived from the display?
If it's not appearing on radio's display, you may need to remove radio from
dash, and post the numbers printed on label or stamped on the metal casing.
As quoted from link provided, Becker serial number should look like, as explained:-
"A typical example of becker numbers are as follows :
Type 1 has a split becker model and serial number such as
Model : BE0837 - Serial : Y1245784
Model : BE1122 - Serial : Y7654321
Type 2 has the becker serial number and model combined to form the complete serial number
Serial : BE411021234567
Serial : BE1234Y1234567 "
Cheers.
Cheers.
ohh i thought you needed the serial car number
i gave you that one![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
on the face plate i only have cdr-220, no other number,
i cant get it with the vin number of the car?
how do you remove radio?
i gave you that one
So you're getting display of radio stations etc..., but no sound.
Is this the case for both CD and radio modes?
If it is, make sure speakers plug / connectors are securely
connected at rear of head unit.
Last edited by Bruce2010; 08-30-2010 at 05:44 PM. Reason: meant to say CD not cassette
yes i got display, i see channels...
is there a fuse i can check?
also, where is the amp located in a boxster?
i have 6 wires cut where the spare tire is located lol
you need special tool to remove the radio i think, i saw that on internet, isnt it?
Haven't worked on Porsche sound systems. However, your
high-level head unit outputs will feed into your amplifier
It definately looks as if you have a problem with amplifier
power / connection.
Pleased to hear you've got radio unlocked, but here's
where I pass over your question to Rennlist community,
for members who will have more specific experience....
Cheers.
PS
There is key/tools for removing Becker radios - usually ebay.
power / connection.
Cheers.
PS
