Info on high mileage '97 Boxster
#31
FYI the infamous oil leaks were mostly on the '89, '90, and early '91 models because Porsche didn't put gaskets between the heads and the cylinders until late '91. However, that "fault" will usually show up before 100k miles. I think they got it pretty well worked out by '93.
Rennlist has a great 964 community...drop on over to that board for a little more research! (I do all the time!
#33
I just hit 90000 on my 98 2.5 and it's every bit as much fun now as it was when I got it. I see quite a few boxsters come through our shop, and it seems the except for the crappy rear windows and the occasional RMS leak, they are very little trouble! Like someone on in this thread said. They need to be driven! In fact the more you drive thenm the longer they last!
ok I'm done now I'm going home!
#34
You think the motor would be worn out after those kind of miles? Think so? Mine has right at 170k on the clock, and believe it or not, the car runs better than new. My mechanic did a major service on the car recently and could not believe the condition the engine is in...These cars, when taken care of and run will last and last. Trust me.
The only reason I don't drive mine all year round is the salt and calcium they sop the roads down with here in the northeast. She rests in the winter, but we play hard the rest of the year.
