Advice on rear size tire for 18x10 rims...
Hi Folks,
I am in the process of getting tires for an '01 Boxster. The wheels are 18x18 ET45 mm front and 10x18 E40 mm rear. The recommended tire size for these wheels are:
Front: 225/40/18
Rear: 265/35/18
My question is: Can I go with 285/30/18 in the rears w/o any problems? Is the car going to look funny given the lower profile of the rear tire? What if I stick with the same recommended profile but use 285/35/18 instead?
If I want to go with 285s in the rear which profile height do you guys recommend?
This Boxster has not been lowered and it would only be driven in the street.
Any advice would be greatly appreciated...Thanks in advance!
Humberto-
Front: 225/40/18
Rear: 265/35/18
Humberto-
calvani,
- Yes you can go 285.30.18's without a problem. [although I did fit GT3 5mm shims to allow them to clear my coilovers]
- The car looks better WITH the 285's ....[received lots of "looks tough" comments]
- 285.35.18 will look stupid.....like tractor tyres. It will also make your speedo inaccurate.... reduce your acceleration.....
Some other issues to consider:
- using 285's increases the cars understeer noticeably !............I had to dial in as neg camber as possible to counteract it.
- using 285's increased the unsprung weight of the rear end considerably.......It made the car unpleasant on rough roads
.....still didnt stop me using them though
BOTTOM LINE:
- if you prefer looks, go the 285.30
- if you prefer handling, stay with 265.35
Cheers
Q
BOTTOM LINE:
Cheers
Q
Bro, I was considering to put Bridgestone Potenza S-02 tires if I go with the 285/30/18. If I stick with the recommended size on the rear, 265/35/18, the
Yokohama AVS ES 100 seems very attractive (A four-star tire for $185/tire in
www.tirerack.com).
Q, thanks very much for all the feedback! This is exactly the information I was after, and it should prove to be useful to other Boxster owners in the Forum.
Given the pros (awesome looks!) and cons (affects:understeer/handling, more weight, higher price) of the 285/30/18s, what do you think of compromising with 275/35/18 ? Yokohamas AVS ES 100, which are great tires, and are available in this size are for under $200/tire....(they don't make 285/30/18).
Thanks again.
Cheers,
Humberto-
www.tirerack.com).
Thanks again.
Cheers,
Humberto-
I would stay with the 265's. Unless you are putting more rubber on the front of the car to balance things out it isn't worth upsetting the handling balance of the car IMHO. If the rear tires aren't filling out the wheel arches you can always put on spacers (I have 15mm spacers all around on the car)
Marc
Marc
Ironman 140.6
Ironman 140.6
I don't know.......that sounds like a recipe for rubbing and understeer.
I'd think you would need a ton of rear camber (more than you'd want for the street) to keep those rears from rubbing. How does it work on your car?
Thanks, Bro...
That's a quite a set-up! Are you using spacers (then again, you do have ET40 mm offsets in the rears)? Are those Michelin Pilot tires?
How does the car feel/handle with that set-up?
Cheers,
Humberto-
Cheers,
Humberto-
On the track, the camber is maxed out and the car handles perfectly. Oddly enough, I haven't changed out the sway bars. I think the reason this works is that the cage (when I had it in) stiffens the car significantly which prevents body twist and bending induced suspension geometry changes which the sway bars are sensitive to. Instructors and other drivers that are way better than I am have told me to not change a thing. I have the car dialed so there is negligible temperature differences across the faces of all 4 tires. It's kinda fun to watch the good drivers roll up the 996TTs and Vetts in it. Something that I aspire to.
Bro
The tires are Michelin Pilot Sport Cups. See my other post for a handling description. The ride is not what I would call smooth on roads that have holes, tar strips or have buckled slightly due to temperature changes and/or truck wear. But then, this is a compromise car and I have modified it to be as such. I like it.
Bro
Porsche Nut
