Clutch Question
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Anyone know if the engine has to be removed to do the clutch on these cars? I'm looking at Boxsters and want to know what I can do myself maintenance wise (including clutch and water pump)
Thanks.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Thanks.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
you can drop the tranny without bringing the engine down, but I think I remember reading that it is easier to bring both down and seperate them on the floor
i just remembered that I read this in a 3.6 upgrade thread, so um... not quite the same scenario
No, leave the engine in the car. The tranny comes out pretty easily. About an 6-8 hour job taking your time. Contrary to popular belief, the dual mass flywheel can be resurfaced, but you will need a machine shop with a surface grinder (your local auto store will not be able to resurface this one). A local shop does them for us for about 60 bucks. I have a blog of doing an RMS seal on a boxster with some pictures of the tranny coming out....You spend more time dropping the exhaust than you do pulling the tranny.
http://www.turbo911.com/showthread.php?t=220
No need to drop the engine at all. It's a relatively easy clutch job since the whole tranny box drops out and you do the clutch work on a bench. You need to have an upper engine support that spans the engine bay and holds the engine from the top, but that should be the only expensive special tool.
You can't do any of the clutch work on a bench, it is bolted to the engine just as any flywheel/clutch assembly. Also, you can support from the bottom with a jack (just don't use the oil pan to do so. There is a spot on the case half.
eh?
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Fuse 24 Assassin
Fuse 24 Assassin
I'm still debating whether or not a Boxster would be better than a 968. Prices in CA are almost the same between an early Boxster and 968. I have the WSMs for a 968, but not a Boxster.
