NOT Porsche coolant!
I’ve had my 2003 Boxster about a year and it has performed well. I just discovered that the coolant in the car is green. I was expecting the Porsche pink. I’ve not had any problems. I’d like to continue with it. Found a few forum discussions of this, but they are from a long time ago, and none addressed the possibility of using only standard coolant.
Might this be a Porsche compatible coolant that is green?
If this is the glycol coolant, will it cause damage?
thanks
Pic for attention!
thanks
Pic for attention!
enorab (05-21-2024)
I have a relative that worked for one of the manufacturers. When I referred to coolant type by color he corrected me. The color does not determine the type. Yes, Porsche factory fill is pink. I drained green coolant when I changed my water pump and radiators, and replaced it with pink zerex. If ou are worried, dump whats in it, and add what you want.
What type of coolant is pink Zerex? Looks like it’s OAT?
at any rate, I’m going to flush and refill with all new so I know what I’ve got. Just ordered a vacuum filler.
I watched Ben Burner's video that I posted earlier (it had been awhile) and I continue to feel very comfortable with using a quality third party coolant ie: Prestone.
With the money I save I buy genuine Porsche brand air. After all more air goes through your engine than coolant. The genuine Porsche brand air should also be used in your tires for a softer ride and more responsive handling.
... I hope nobody takes the above seriously.
Scott O'Connor (06-21-2024)
With the money I save I buy genuine Porsche brand air. After all more are goes through your engine than coolant. The genuine Porsche brand air should also be used in your tires for a softer ride and more responsive handling.
No it comes in big compressed air cylinders. They also sell a special frame, like a roll bar, that allows you to install the cylinders above the roof. The alternative is to tow a small trailer for the cylinders (best to always have 2 in case you run out). Other than the weight of the mounting frame, the weight of the cylinders, the weight of the air and the work of exchanging the cylinders there is no down side to doing this.
No it comes in big compressed air cylinders. They also sell a special frame, like a roll bar, that allows you to install the cylinders above the roof. The alternative is to tow a small trailer for the cylinders (best two alway have 2 incase you run out). Other than the weight of the mounting frame, the weight of the cylinders, the weight of the air and the work of exchanging the cylinders there is no down side to doing this.
https://www.mez.co.uk/lucas.html
Lucas denies having invented darkness. But they still claim "sudden, unexpected darkness."
Lucas--inventor of the first intermittent wiper.
Lucas--inventor of the self-dimming headlamp.
The three-position Lucas switch--DIM, FLICKER and OFF. The other three switch settings--SMOKE, SMOLDER and IGNITE.
The original anti-theft devices--Lucas Electric products.
"I've had a Lucas pacemaker for years and have never experienced any prob...
Did you hear about the Lucas powered torpedo? It sank.
It's not true that Lucas, in 1947, tried to get Parliament to repeal Ohm's Law. They withdrew their efforts when they met too much resistance.
Did you hear the one about the guy that peeked into a Land Rover and asked the owner "How can you tell one switch from another at night, since they all look the same?" "He replied, it doesn't matter which one you use, nothing happens!"
Why do the English drink warm beer? Lucas makes the refrigerators.
Alexander Graham Bell invented the Telephone.
Thomas Edison invented the Light Bulb.
Joseph Lucas invented the Short Circuit.
Recommended procedure before taking on a repair of Lucas equipment: check the position of the stars, kill a chicken and walk three times sunwise around your car chanting: "Oh mighty Prince of Darkness protect your unworthy servant."
My 2001 Boxster S came with green coolant when I purchased it used from a Porsche dealer in Chicago in June 2009..... It's been in there since....
Like Lucas replacement wiring harness smoke you have to be careful not to get the cheap imitation.
