Courtesy/Dome Light
99 Bosxter Base...I need to replace the dome light assembly because of a bad micro switch(windows don't fully close). So... I have a replacement but its a 2001 I believe. It has a nicer fixed dome light not the rickety one in the 99. Of course it has a different size connecter. The other connecters for the micro switch and infra red are the same. Was thinking of just fabricating a new harness. There are only 3 pins. I assume 1 common ground and 1 switched and 1 for continuous. Couldn't find the schematics in the factory serve. manual. Any thoughts about this. Thanks .....Hate that rickety one....ugh
If the dome light is on when the doors are closed that suggests a problem with the door latch switch. If the window doesn't fully close when the door is closed that's a pretty big finger pointing at the door latch switch. But there is a possibility the fault could be with the door lock controller/assembly.
Briefly, the tech told me and demo'd this to me. Pull either inside or outside handle but stop just short of activating the door latch release. The window should drop. Release the handle. The window should go back up.
Open the door and the window should drop and remain down all the time the door is open. Close the door and the window should go up once the door is closed.
yea, the dome light will not fix your window drop issue. it's separate from the top latch switch
