PSS9 vs. JRZ
PSS9 vs. JRZ
I'm trying to decide between a JRZ and PSS9 suspension. Does any know of any reviews or spec pages that will provide the data to help me decide?
Has anyone here done either upgrade? I would like to hear about the results.
GT3 player par excellence
go with pss9's. if you want jrz triple adj, you should then get all spherical joints, slicks, magnesium wheels, gut out the whole car of excess wt and be racing. else, i dont' think you really get your money's worth with jrz. greg fishman can give you more info on jrz's i am sure.
Thanks for the comments mooty. I was actually considering the two way adjustable JRZ's. As I believe the triple adjustable's have an external reservoir, which will bump me up into a class I don't want to be in.
I'm not sure about all those mods right off the bat. But I do plan to be racing this car by the end of March. Getting quotes on a cage as I write this .
If you are planning on racing go on and get the JRZ's or Motons . If you don't you will be replacing the Pss9's within a season, I bet.
Best thing about JRZ's or Motons is that you can change spring rates without revalving or rebuilding them. I would suggest you look at the Moton CLubsports. Great value for what you get. Probably cost around $2500 compard to the "professional" version that runs over $4K.
Check with Steve at Rennsport Systems info@rennsportsystems.com he knows his stuff.
Actually all of the JRZ's and Motons have external reserviors, except for the single adjustable models. (not 100% sure if Moton makes single adjustables though)
http://www.rennsportsystems.com/moton.html
Thanks for the reply and the info Greg. I was considering a Moton until I found out that they do not make a setup without an external reservior. I talked to some guys from Hartmann Motorsport in L.A. and they lead me to believe JRZ had a two-way adjustable shock that does not require an external reserviour. Since that does not sound like it was the truth, I guess I'm stuck with PSS9's. Oh well, I know a couple people with PSS9's on their 986S and they like them a lot.
Again, thanks for the help.
netmaniac, it wasn't clear to me that you are putting a cage in your car to race it. if you are RACING not just DE, i would do moton or jrz like greg mentioned. PSS9 is a bit soft on the track.
Well, it's not going to be a dedicated race car. At least not just yet, maybe in a year or so.
What makes a Moton so much better than a JRZ? As I understand it they are the exact same components just put together in a different plant.
Mike,
Everybody I have talked to about these types of shocks always says for the same money the Motons are the ticket. Reasons include, durability and quality control and customer service. I don't think anyone has mentioned that Motons are "faster".
I can't see how JRZ would have a double adjustable shock without an external reservior, but that sure doesn't mean it isn't true. See if they have any literature on them.
What are your limits on spring rates in the class you are currently in? If that is unlimited then I would look at a single adjustable shock. I am only familar with the JRZ's. I went that route and then later had them made into double adjustables by a shock engineer in New York, name is Joe Stimola.
Moton and JRZ both make great dampers. So do Penske and Ohlins and a few others. Your best bet if you are serious about going racing, is to find a good suspension engineer and buy what they are comfortable working with.
-Paul
-Paul
Thanks Mark. Unfortunately there are only about 2 or 3 local PCA races a year here on the West Coast. But the POC has quite a few more. And their rules state:
26.2.3.10 Any shock absorber, and/or re-valving of shocks, is allowed, except race shocks (externally adjustable and/or external reservoir).
Which after re-reading looks like I might not be able to use PSS9's either. Wow, I guess that means H&R's. Cheaper sure, but it's almost like "What's the point?". I think I need to look into this a little more.
Well, I am going to do as many PCA races as I can (in fact my first one is going to be this March). I might even be able to scrounge enough time and money together to make a few Mid-West races. Given the rules constraints in POC I might just bail on the idea and focus on PCA and maybe a few TCRA or NASA or something.
I put a lightweight flywheel and it bumped me into Production skipping over Improved completly. I was approximately 3.5 seconds off the pace of the other KP cars this past weekend in Vegas. Oh well.
Anyway, thanks all for your replies and help. I need to do some more homework.
Mike, I might have a solution for you...
I just bought a Boxster S and the previous owner had put in higher valved bilsteins (along with stiffer springs). They aren't externally adjustable. Spring rates are 600 pounds up front and 800 in the rear.
I would use it myself except that I'm upgrading from a 2.5L boxster and I put in Leda double adjustables with an external reservoir. I'm planning on moving that to my new car.
