scca stock class becoming street class!
Old 03-22-2013, 01:03 AM
balefire
balefire's Avatar
Default scca stock class becoming street class!
Just thought this deserved its own thread.
http://www.solomatters.com/2013/03/s...sal-explained/
Street tires!
Camber mods!
Sway bars!
Finally many popular low budget mods that would make autocrossing more fun are allowed in the lowest prep class.
Should make the low powered Porsches eg boxster cayman more competitive.
Old 03-22-2013, 05:20 AM
knfeparty
knfeparty's Avatar
Yeah as soon as I get a competitive stock class car they do away with stock class. Go figure. I will miss R comps.
They already have this class; it's called STX. Why didn't they just tone down an ST class instead of totally change stock?
Old 03-22-2013, 11:49 AM
PedalFaster
PedalFaster's Avatar
Three points:
1. knfeparty -- the proposed Street class is vastly different from the existing ST classes, including STX, in both intent and application. Read balefire's link.
2. There's no need to "miss R comps" -- if you want to keep running your car on them, go to Limited Prep Street Prepared. If you don't know what that means, again, read balefire's link.
3. This is a proposal, not a done deal. It won't necessarily be implemented in its current form; it may not be implemented at all. If you like it, write a letter to the SEB at http://www.sebscca.com. If you don't like it, write a letter to the SEB at http://www.sebscca.com. If you like it parts of it and dislike others, write a letter to the SEB at http://www.sebscca.com.
Old 03-22-2013, 08:11 PM
sjfehr
sjfehr's Avatar
I'm really excited about the proposed new Street class I'd have long ago abandoned stock for STR if I could have. The new proposed Street class gives me everything I wanted to switch to STR for, but without the extra crap I was unwilling to do to my DD.
I especially love the new allowance for extending slots for more negative camber; it's really going to help us Boxsters dial out a lot of that understeer.
SEB is looking for feedback. If you like it, too, write your letters in support! I can guarantee you people who don't like it are writing theirs
http://www.sebscca.com/
Old 03-22-2013, 08:46 PM
ToSi
ToSi's Avatar
This is a bad idea.
1) stock needs fewer allowances, not more.
2) r-comps are the key issue - replace w/ 140 or 200TW & leave the rest alone until the dust settles.
3) take away the fragile tires & all of the sudden, tire life improves
4) open camber means you'll be running 2.5 to 3 deg to keep up w/ the fast guys
5) non-remote reservoir double adj shocks are still expensive.
Think about what a car 'fully prepared' to these rules becomes:
  • F&R ultra-stiff sways,
  • Ultra-stiff shocks,
  • Ultra-aggressive alignment,
  • Smaller diameter wheels (for lowest CG & improved gearing).
Sound like something you'd want to drive as a dual-use / commuter <-> entry-level autocross car?
Old 03-22-2013, 10:13 PM
sjfehr
sjfehr's Avatar
I'm kinda torn on that, ToSi. Philosophically, I still think stock class should be STOCK. Ideally, I feel someone should be able to drive a car off the lot, adjust pressure pressures and go. The problem is, most are are complete dogs out of the box, and getting worse. The trend for cars right now is heavier with intrusive traction control, horrible understeer. Even stock Porsches understeer horribly and have traction control that can't ever really be turned off at the switch. SEB is trying to design the new class around the reality of car performance limitations, and I can see their point. So while philosophically, I don't like the increase in allowances, practically speaking... they're exactly what I want to do to my car, which I look at as a DD first and Autox car second.
Stiff sway bars don't compromise ride comfort as much as stiff springs do.
Adjust your adjustable shocks back down for the drive home (Or just stick with stock porsche shocks which are pretty good already)
Camber doesn't eat tires, toe out does. Neutral toe might be slightly slower, but it's a reasonable compromise.
Smaller diameter wheels have cheaper tires, too. Win-win right here.
Old 03-23-2013, 11:24 AM
balefire
balefire's Avatar
I thought this quote from another forum encapsulated the overall philosophy and how STREET is different from STX, etc.
Street: 200 TW, stock wheel width, full alignment and reasonable shocks but no springs, and no power mods except cat-back
ST: 140 TW, wider wheels, stiffer springs and ride height tweaks, and full intake/exhaust and reasonable tuning
SP: R-comps, infinite wheels, near-infinite suspension, tons of tweaking to your existing engine
SM: R-comps, infinite wheels, near-infinite suspension, near-infinite power mods (engine swaps, turbos, etc.)
If you still like R-comps but with the stock class mods, limited prep SP class.
Originally Posted by ToSi
This is a bad idea.
I think anyone that wants to autocross their car regularly but keep it a DD will be happy to have the compromises of stiff sways, shocks, and camber negative alignment. I have done this for 10 years and am happy with my tire wear and my wife and kids have never complained about the ride / suspension.
I think extremely few people will downsize their wheels just to get better gearing as they could already do that with lower profile tires. I think the wheel diameter +/-1" helps those with 14", 19", and 20" rims who previously have had very few choices for good tires.
Old 03-23-2013, 01:55 PM
Audii-Dudii
Audii-Dudii's Avatar
Unless the corresponding realignment of car classifications screws up everything, the proposed "Street Class" rules are, to paraphrase Mary Poppins, "practically perfect in every way" and I enthusiastically support them.
In fact, I am so enthusiastic about this proposed class, that I've already started acquiring parts to make the transition with my Cayman S and, fingers crossed, will have my car prepped accordingly for the next local event on April 14th. I will then use the remainder of the year to get it dialed-in and hit the ground running come January 1, 2014, when I plan to start a serious National-level effort...
We shall see what we shall see, eh?
Old 03-23-2013, 02:36 PM
sjfehr
sjfehr's Avatar
Be careful- they're just proposed rules and may well change or be rolled back entirely.
Old 03-23-2013, 03:58 PM
Audii-Dudii
Yes, I know ... btdt with the SCCA many times before, unfortunately.
While I know there will be some inevitable push-back from certain quarters about the current proposal, to my mind, it makes so much sense on so many levels, I would be very surprised if it's scrapped entirely or even if it's significantly revised, especially as (IMO) the SCCA clearly has a problem that must be addressed and sooner than later.
Worst case, I will be out ~$4,500 for a few months while everything gets sorted and if it's scrapped, I'll either sell the parts and take a loss or go run with NASA instead. But if it does come to be, I foresee that a lot of testing will need to be done to optimize one's car setup and getting a jumpstart on this is a gamble that I'm willing to take...
Old 03-23-2013, 06:19 PM
ToSi
ToSi's Avatar
Sounds like you guys in support of this are blinded by perceived near-term advantages to your own particular cars.. if everyone is allowed these changes, the net competitive balance will change but not necessarily for the better.
For example, re: wheel sizes. Understand the intent is to allow cars stuck w/ odd sizes (19's +) to downgrade to more favorable sizes. The catch is that a car that comes w/ 16x7 wheels (common size usually w/ a 25" od tire) can now downside to 15x7's & run the same width tires in a 23" OD size.. Result? 1" lower CG, better gearing.
Bummer if someone in your class can do this but you can't. Double bummer if you can but don't want to live w/ the speedo error & goofy look. Big deal, right? Just get 2 sets of wheels.. thought that's what we're trying to 'fix' in the first place..
Bigger sways F&R sounds like a good idea right? Which ones? How many more iterations will you need to try to find the set that works the best? Bars are springs that function in roll, wouldn't add more 'spring' without more damping right? Now those fancy shocks are really required to make the most of things.
The net effect of increased allowances is to further separate the (perceived & otherwise) competitiveness of the newb who shows up w/ a truly stock car from the fast guys. If you want to encourage participation in the entry-level class, the goal should be to minimize the effect of car prep.
The base classing should account for inherent performance differences between cars, Achilles heals & all.
What really needs fixing?
The biggest current gripe w/ stock is the cost of r-comps & associated hassles to run them - get rid of them & the need for alignment allowances goes away too.
IMHO, the real issue for Porsche owners is the lack of a suitable place in ST* & the generally screwy progression between classes. ST should be SP-light -> minimal powertrain changes, bolt-on suspension & wheels, everything has to fit under stock bodywork, inclusive of *all* makes / models. I think this is really the class you're looking for.
Old 03-23-2013, 08:31 PM
sjfehr
sjfehr's Avatar
Surely you must realize sports cars are but a small minority niche in Sports Car Club of America, and not the focus of the club! Why would they be allowed in ST? Seriously, though, one of the SEB comments is that although they're getting constantly pestered to class cars in ST, it's clear most of those people don't want ST- they really lwant Street class. So they proposed creating it. Certainly tempers my desire for ST, as Street offers me everything I really want and doesn't force me to do much more.
I've been thinking about the proposed rules quite a bit, too; I've decided I'm opposed to the +/-1" wheels and ECU mods, for sure. I am extremely excited about street tires and camber. I have no false optimism that this will increase the competitiveness of any porsche besides maybe the GT3- the moment it looks like a Boxster is going to beat a Miata, S2000 or Corvette, it's going to get bumped up a class. I'm thinking front OR rear sway (not both) is probably still the best sweet spot- camber will help balance the car.
How much front negative camber can a 986/996 get by extending the slots?
Old 03-24-2013, 12:40 AM
edfishjr
edfishjr's Avatar
I think the "both sway bars" was a total miscalculation and will not be implemented. ECU mods have been met with almost universal disdain as well... hard to see that implemented either. Limited Prep in Street Prepared? Please get real. Not gonna happen.
The good thing for all modern Porsches (GT3 excepted) would seem to be the camber allowance. But, remember that camber allowance + street tires will require massive re-ordering of the "street" classes. Boxster/Cayman versions all probably go up one level from where they are now. Alternatively, Corvettes all drop a level. C5Z06 against 1st gen Cayman S/996-50th in AS. Standard C5, maybe with a small rear tire option to solve its 2nd gear problem and make it faster, in BS.
Old 03-24-2013, 09:45 AM
sjfehr
sjfehr's Avatar
It's a real possibility that Boxster/Cayman will all go up a level due to camber, but I really don't think this will hurt corvettes as much as the doomsdayers are predicting. Corvette isn't a great autocross car because it can put 400hp to ground, it's a great autocross car because it handles so fantastically, and that's not going to change. Plus, the new crop of street tires are just fantastic and damned near equivalent to the top performing DOR r-comps when many of those C5s were built, so it's not like we're forcing them to run linglongs or anything. I'm actually getting less launch tirespin on my ZIIs than I ever got on my V710s. I've heard a few vette drivers that are planning tests, so we should hopefully know soon. This year's RT results should help shed light as well.
I'm really surprised so few complaints from FS drivers, whom will be hit a lot worse. I've yet to hear a single FS driver complain, though- plenty of SS drivers referencing FS & AS, but few from those classes commenting on it. FS is more homogonous, though, and most cars will be hurt about the same. FS pax will change for sure, a few cars will likely be shuffled, and life will go on. I fear Elise may end up the real loser here, as it may find itself relegated to SSP... At least they could finally fix the oil starvation issues, I guess.
ToSi
ToSi's Avatar
LOL, SCCA is FuCT if NASA picks up autocrossing.
Seriously, though, one of the SEB comments is that although they're getting constantly pestered to class cars in ST, it's clear most of those people don't want ST- they really want Street class. So they proposed creating it. Certainly tempers my desire for ST, as Street offers me everything I really want and doesn't force me to do much more.
Exactly. People want a truly streetable limited-prep class, not this half-baked concoction. Fix ST, street tires in Stock.
Quick Reply: scca stock class becoming street class!
