Your PCA Region AX classes?
In the Chicago region we've held pretty strongly to Parade rules and classes. Problem is - this works for Parade, which has lots of participants and a wide variety of cars. It doesn't work so well for our region, which usually has 25 participants on average (the most we've had in my time as a member was close to 40), and easily 95% of those participants are in Boxsters and 996's. We wind up with 2 classes with 8-10 people in it, and then 5-6 straggler classes with only 1-2 participants. IMO that takes away from those who win in the bigger classes (as they had to beat 8 others) and gives wins to folks who are only racing against one other person. (We do "roll up" results in classes that have 2 or less in it - but then sometimes it winds up sucking anyways when you've got a poor guy in a 1.7L 914 "rolled up" into the class with Boxsters....)
We're trying to figure out a way to break it up a bit, even the classes out while making the field more competitive for everybody. Enough people complained to our AX coordinator and board of directors that I think we might have some momentum to get the board to sign off on finally deviating from Parade rules.
The obvious choice would be to break things up by power-to-weight... but then for the handful of folks that have modified their cars, we'd be on the honor system to ensure that they are reporting their power accurately. It also doesn't really account for suspension changes, which IMO help more than power does when it comes to AX.
Other clubs (Chicago Audi, Chicago VW, and Chicago BMW) seem to do a "points" system based on modifications, where certain models start off with a certain number of points, and then you add/subtract based on engine size, suspension mods, etc. Your class is then determined based on the number of points you tally up. I like this method but it will be tough to come up with a "fair" points system. It, too, also relies on the honor system.
We don't take our AX too seriously, it's more about fun for the participants and it'd be nice to give more folks a fair shot at taking home a trophy. AX in the Chicago region tends to be used more as a "gateway drug" so to speak for getting folks to move into DE so we'd prefer that folks come away having had fun rather than feeling frustrated.
So how do you do it in your region?
We actually do use the medium sized region classing suggestions from the PCR's for our big multi-region event. That did reduce the 1 car classes significantly, but not entirely.
What would be useful would be if there were a PAX system based on the class structure in the PCR's, but even that would have it's pitfalls were it to exist.
IMHO, putting together a classing system that is fair to all is the Kobyashi Maru of our sport. :-)
Brian
http://shn.pca.org/autox.php
I think they usually have between 20 and 30 participants, so I don't think a class win means as much to most of them as their overall position compared to how they did at the previous events. For a while some of the relatively new-to-AX Porsche drivers didn't like getting beat by Miatas and Mini Coopers, but they're probably used to that by now.
We typically have about 55-70 entrants and up to 40% will be non P-cars.
You can see it here: http://www.oregonpca.org/events/auto...s-regulations/
This is abbreviated not exact but basically classes are broken down two ways: first by model, then by mods. Models are grouped together based on performance. To be in Stock the car must be stock. Steering wheel, seats, brand of tire. That's about it. Factory performance options are all okay. Anything- any ONE THING- changed moves the car up to Prepared. Prepared cars may run R-compound tires, aftermarket springs, roll bars, header- very long list basically anything you could bolt on in your garage. Beyond that, Modified cars may have a long list of engine mods.
While it may seem odd for a guy who just mounted R-compound tires to have to run against cars with completely reworked suspension and exhaust, it does at least place a limit on Prepared- and this has worked great in our Region for a very long time.
With only 25 cars turning out you might want to consider something more creative, such as running classes based on actual performance. Take the car out of the equation. Just a thought, but if you say took an average of all prior years runs and divided those up into roughly equal run groups- top 5 Group A, next 5 Group B and so on. Similar to divisions in other sports (cycling, racquetball) where groups are based on ability. Nobody cares how spendy your bicycle is, you need race wins to move up. Same concept here. Anyone who has done autox very much is familiar with the situation where a good driver in Stock is killing the times of some gus with much "faster" cars. This just recognizes that reality, helps balance out the run groups, and helps put the emphasis back where it probably should be anyway, on driver skill.
"M" class is our "catch all" or "anything goes" class. The guys that show up with Hoosiers on an otherwise stock car (so far only one of them in the last 3 years) has to choose whether to take the time penalty and run with the other stockish cars, or run in M against the 2-3 ringers we have in the club (one of them driving an original '72 911 S-T....)
This year I am getting "beat up" to go to Parade classes or the medium parade rules. That does not sound like a solution that is going to solve any problems.
That being said, you might consider using the small event classing definition in section A-9.1 of the PCRs since you are only getting roughly 20 Porsches at your autox events. I could build an AXWare class definition file to match the small event car classes if that would help you out. Just let me know.
Of course, you are free to use any car classing scheme you like for your region. I'm just trying to help.
Cheers,
Henry
PCA National Autox Chair
Surely there are 914s, 356's, 944s etc out there that should be coming out to events. Were they running there 5 years ago? 10 years ago?
PCA Potomac gets about 50-60 cars, about 10-15 of which are non-porsches. We use the small or medium PCA classes and find they work ok, but as mentioned, some classes become "catch alls" making it harder for some of the older cars to compete for class wins.
Why not just let folks enjoy their class wins? Or, are you looking for a paxed system so the 996 driver can learn he was actually slower than the 914 2.0 driver was
Also it seems to me that, assuming a fair and equitable course design, the top times from each class are fairly close regardless of car type and class, meaning its the driver and not the car that matters.
