Need to beat the Boxters, what's the "best" stock rubber?
So I came in 3rd this year in the PCA stock class. I'm running a 95 993 C4. I weigh a little more, & only have 270hp, but the dam Boxters are tough to beat. It only happened a couple of times this year.
So the car is totally stock, M030 suspension, Sumi HTZ III rubber. What will make me faster & keep me in stock class?
Tires are 205/50/17 & 255/40/17
PCA stock doesn't allow much car change other than trying different tires and pressures. Do you have much room to improve as a driver? A well-driven Boxster S can be tough to beat indeed.
A '02 Boxster S was the fastest of all stock class cars at the '08 Parade autocross (72.11). A GT3 had the second fastest time (72.36), and a '07 Cayman S took third fastest (72.83). A '96 993 C4S took S07M class with a 76.95. I guess I should mention that the Boxster driver was Danny Shields, multiple-time SCCA National Champ. My point is that autocross outcomes are heavily influenced by driving skill. You may be unlucky in having to go up against better drivers. I know the feeling.
Jim is spot on, Boxters are hard to beat. I have wupped them with the RS running on A6s (them also) but not by a lot. Only my second year doing autocross though. Check the classes that run in your club. Maybe if you modify your car it will put you into Production * class and you can run alone in your class. Worked for wifey when we put seats and harnesses into the 997C2S.
2) Alignment. Get toe closer to zero degrees (it only serves to stabilize the car) on both ends and maximize camber. With m030 you can lower the car on some Porsches (mine you can, I think newer ones they don't trust the end user anymore); do this and you'll have a lot more responsive ride, but it will also be a lot less stable (great for autocross, but not so good for, say, inexperienced track driving).
All other factors aside, I simply love the Michelins Pilot Sport PS2s, they are an amazing street tire. To quote another member "I have PS2's on my car now and unless I am flat broke, I'm going to keep putting them on my boxster. Excellent traction in all sorts of weather..."
I put a set on at the beginning of the season (January) and am still leading my local PCA autocross class by a landslide.
We have 2-4 Boxters in my class, 3 run just about all the time, there are about 15 total in the class. The person who came in 1st with a 05 Boxter, has been to nationals a few times, & it just about always 2sec in front of me. I'm sure everything that can be done to the car has been done.
1) Tighten the nut behind the steering wheel. You should be able to do a whole run without having the tires squall. If the tires are talking a bit, that's okay, but if they're begging for mercy the whole run, you're losing time.
Tires really don't squeal at all, I'm pretty smooth. Any time it's wet, I clean up. My C4S is set up, & has toe out on the front & 0 toe rear with a aggressive alignment. It's totally fun to drive, but not for my daily driver.
Can't lower the car, only the fronts are adjustable, & it's corner balanced, but aligned to stock specs. It's my daily driver, & I need it to be stable with no drama for when, my other half drives it.
I just want to know what the hot stock class tires are!
The Bridgestone Potenza RE-01R, the Dunlop Direzza Sport Z1 Star Spec, and the Yokohama ADVAN Neova AD07 are the tires that dominated the street tire classes at this year's national championships.
Tires aren't going to get you two seconds -- you need to tighten the nut tighter.
As an aside, I think you may be confusing the Porsche Parade (not much competition) with the SCCA Solo Nationals (lots of competition). Only a handful of Pacific NW Region PCA members attend the Solo Nationals regularly, and none of them run in S4.
. The Bridgestone Potenza RE-01R, the Dunlop Direzza Sport Z1 Star Spec, and the Yokohama ADVAN Neova AD07 are the tires that dominated the street tire classes at this year's national championships
I will Second these choices, I ran the 08 Parade in My 04 550, and was the fastest water cooled car.
being beaten by only, Bobby Smith for FTD. I ran a 69.125. I ran Production because I ran Hoosiers, the only Modification to the car was a GT-3 sway bar with custom links, and Alignment. it was completely stock other than what was stated.
Danny Shields was running Bridgestones, these tires are worth more than second over your sumi's.
just my thoughts.
thanks Rob
just my thoughts.
thanks Rob
just my thoughts.
thanks Rob
just my thoughts.
thanks Rob
Thanks, I leaning towards the RE-01R. The Yoko's are great tire, but really expensive. It just sucks, that this is my daily driver, & I know that she will go through 2 sets of rear tires in a season!
I would second the Yokohamas. Night and day different compared to your Sumis. If these are going on the daily driver, I would suggest a second set of wheels for the Yokohamas. You will get better life my not using up that precious rubber while commuting and Cup II wheels are readily available for $500 or less and will likely be the same price should you decide to sell them (i.e. free "rental" wheels).
Even better would be upgrading to 18" wheels with the Yokos but that gets pretty spendy.
And yes, there is no substitute for tightening the nut! I've been doing this for over 16 years with some nice success over the years and I am still learning to go faster and be more CONSISTENT.
Good luck.
Good luck.
If your looking for more advice....you can try Karl at Tight-n-tidy (http://www.tightntidyracing.com/). I've used him for a while for my tire swaps. He's big into SCCA and can pass along some good info on tire choices for you.
I have 4 cars right now as luck would have it. The Boxster S I just picked up has put all the rest of my cars in sleep mode. It's all I ever want to drive. I drove it to work yesterday with 27 degrees outside on summer tires, just because the weather man said it was going to get up to 50 in the afternoon. I had a 97 Boxster that I sold a few years ago, this Boxster S is so much better. I know some think it's a chick car, but I have a green one with a hard top, and really don't care what anyone thinks anymore. I've added 18s since this picture, and I have a bunch more stuff to upgrade.
clarification
No, I do not have another set of rims for it, just the stockers, & I can't get the larger 18in turbo twist, that would put me in prepared.
I'm going to just get the RE-01R & get another set of rears half way through the year.
I drive about 10kmi a year on the car.
