Heel/Toe technique with PCCB's
I posted a question on the 997 forum and it was suggested I try in racing too. But since I'm really mostly interested in this technique for autocross I'm hoping someone over hear can give me some input:
I have been really struggling with heel/toe with my new car which has PCCB brakes. I know the basic technique and was pretty proficient with my 996. The problem is that the brakes are so touchy that it's very hard to "feather" the brakes and heel/toe when you don't need so much braking that you hammer them.
I used Rennline pedals on my old car and about ready to order another set because they do make it easier.
One suggestion that I have received is that on the C4S the brakes have double boosters and pretension when quick pedal movement is detected.
I'd appreciate any advice anyone here may have.
Thanks.
Tony
Thanks.
Tony
Sorry no one has replied here.. Not a lot of PCCB equipped AX cars.
In my experience for AX, the courses I have run are not "finesse" enough to require 1) lots of shfting and 2) lots of Heel/Toe technique.
Most events I have run have been get to 2nd and leave it there. AN occasional shift to first for a tigt turn-around, but even then, sometimes lugging in 2nd is quicker than the time spent down and up shifting.
To me, AX is lots of abrupt movements.. hard on gas, hard on brake. Perhaps you are overthinking your driving to focus on a smooth H/T. Then again, maybe you run on 100mph AX courses where it is an issue.
In the end, its just seat time and familiarization with what you car has.
I'll have to echo the above - it's really about seat time and experience. There really is nothing wrong with your PCCB's, they simply require more finesse than your old brakes did. Practice makes perfect.
I don't have wider "heel-toe racing pedals" on my street car (although my race car will) and so instead I drive with running shoes that have a wider base near my toes, which help with reaching both pedals. When I put on my narrow Puma racing shoes, I can't heel-toe worth a damn.
+1 to what Racer said. I have PCCBs and don't heel/toe. I don't downshift because our courses don't need to drop into 1st gear.
Like Racer, when I need the brakes I'm really on them, trying to get my speed down to whatever the next segment dictates as fast as possible. There is no feathering of the brakes when I'm driving. If I did that then Rich might beat me. I can't have that.
Cheers,
Cheers,
Thanks guys. On my local PCA course we do get into 3rd gear and around 100mph at one point and in the 80's in a couple of others. I have purchased a set of Rennline pedals and a lifter plate for the gas pedal to even up the pedals some. Once I have them installed (hopefully this weekend) and the weather warms up a little I'm going to practice again.
So far my practice with stock pedals has been pretty fruitless. I think that finesse IS probably the answer - because the PCCB's are very touchy. When I'm going say 60-70 mph and really brake hard the car stops so damn fast it's hard to get the heel/toe shift done! I think dropping down from 100 mph would be easier because I'd have another nanosecond to get it done.
I'll keep trying...
Thanks for the input.
I'll keep trying...
Part of the problem might be electronic. The newer Porsches don't like to have the accelerator and brake pedals pushed simultaneously, even for heal-toe work.
Proper driving shoes and practise practise practise. I have the PCCBs but only dropped down to first a few times last season. Mostly quicker to lug around tight spots. If I do drop to first I need to make sure there is a section ahead to upshift without upsetting the car. BTW, need a real sharp jab to drop into first with these cars.
